Um...Me123
- Aug 6, 2005
- 174
- Joined
- Aug 6, 2005
- Messages
- 174
I'm sorry I have to ask such a dumb question but every othere resourse is eplaining how to uses caps and resistors in AC and can't (to a full extent) answer my question.
I can't figure out what AC is. I know what it stands for and that it goes at 60Hz. I used to think there was a positive and a negative and the positive turned on and off at 60Hz but after learning about bridge rectifiers and seeing many otherr things I pretty sure its the polarity reversing itself at 60Hz. (AS in lead 1 is + and lead 2 is - then lead 1 is - and lead 2 is + and so on) Is this right? I almost always am working with DC circuits but I stumbledd along a problem while wiring some outlets in a PSU. I have 2 (light) switches and 2 outlets and I want to control the oulets with the the switches. What I've done so far is wire the 2 black wire screws (on the 2 outlets) together (which is my mistake i think) and wired the white wires through the switches. Then the mains that comes from the wall goes to the 2 outlets black wire and to the 2 switches. In a DC circuit this would be fine but i think I have it wrong...Maybe...if the power is being supplied to both black wires half the time but it has nowhere to ground because the white wire switch is off then I'd be ok for eing able to switch it right?
Thanks guys--if this is too confusing due to my wording I could make up a quick schematic for you if you like.
