QW-ms305D setting constant current?
Martaine2005
May 12, 2015
5,318
Hi all, my son’s friend has bought two qw ms305d psu’s amongst other test gear. They are new. He had a problem not being able to set constant current. My son said “my dad will know”!!. I agreed to go there yesterday (Sunday). Well, I d/l the manual in chinglish. I watched several YT vids. I can’t do it!. Manual says to dial in between 3 and 5 volts then short the output leads while dialing in the required current.
I couldn’t get voltage to display without turning the current knob slightly. Then I set the V to 4v. I shorted the output leads and the current led displays. I tried to set the CC but nothing. Display stays at 0.00.
I sheepishly told him to buy better equipment and that I would ask you gents on here. My comment was more embarrassment as I know he can’t afford it being in university with my son. Have you guys got any ideas?.
I almost gave him my old Maplin psu, but thought better of it
Thanks Martin
Audioguru
Sep 24, 2016
3,656
Look on You Tube for a test of its current regulation NOT WORKING. The test person contacted the seller Who KNEW ABOUT IT NOT WORKING and gave a refund. Cheeep Chinese Junk!
Arouse1973
Adam
Dec 18, 2013
5,178
Hi Martin, it's been a while, hope you are well. Got any pics of these PSUs. Ads
Martaine2005
May 12, 2015
5,318
Hey Ads, been emailing you for decades it seems..
Yes am well thanks.
I will ask my son to get some pics on his phone. I will try emailing you aagain later. I am back in the UK now. Keep well and hopefully speak soon.
Martin
Arouse1973
Adam
Dec 18, 2013
5,178
Yes am well thanks.
Martin
Hi mate, not been getting any emails. PM me your email and I will respond. Ads
Martaine2005
May 12, 2015
5,318
Quick update here.
I have had another look at these as seller has not responded.
My findings are interesting. Shorting leads for CC null etc.
I turned the heat up and shorted at 9v. A little spark and CC was set. I tried again at 13v, same result.
Seems these SMPS do work albeit differently to the manual. I have warned my sons friend to unplug them when not in use.
Both were accurate with regard to voltage. I only had a hand held DMM with me.
Martin
