Rabbit Ears Problem
I bought a new TV (regular one not HDTV), and my rabbit ears will pick
up the VHF (2-13), but not the UHF. They worked on my old TV (15 years
old). The ears have three connections, one cable looking with a thin
wire in the middle which was what I used on the other set. I tried
connecting both of the other wire sets to see if one was UHF, but each
time the VHF worked, but not the UHF. I checked in the manual, and they
mentioned buying a combiner for the two sets of wires, and I checked at
Radio Shack, but they were not sure if that would solve the problem.
The big cable from the rabbits ears would appear to be a built-in
combiner. I hardly ever watch the UHF, but was wondering if my rabbit
ears are too old, and and there is a different electronic need or
something.The manual mentioned some electronic settings 75 ohm?
Tom
T Shadow
Tom
IS the TV is set for cable or UHF/VHF?
Charles Schuler
I'd guess that your rabbit ears are OLD!. Toss them and buy new ones
(again, I'm just guessing).
The problem was the that I had not selected TV instead of cable. I
guess I should read the "book" they provide, but since I do not have
cable it never occurred to me that you had to program the set before
you began to watch it.
Tom
Deke
Tom
DUH!
T Shadow
IIRC, my first cable ready TV came set for UHF but most people have cable
now.
Sam Goldwasser
There may still be way less than optimal performance if the "rabbit ears"
are simply two extendable antennas. UHF wants a different sort of
configuration and is typically a single loop or bow-tie. So, a proper
indoor antenna should have both with a combiner if there is only a single
75 ohm input.
--- sam | Sci.Electronics.Repair FAQ: http://www.repairfaq.org/
Repair | Main Table of Contents: http://www.repairfaq.org/REPAIR/
+Lasers | Sam's Laser FAQ: http://www.repairfaq.org/sam/lasersam.htm
| Mirror Sites: http://www.repairfaq.org/REPAIR/F_mirror.html
Important: Anything sent to the email address in the message header above is
ignored unless my full name AND either lasers or electronics is included in the
subject line. Or, you can contact me via the Feedback Form in the FAQs.
Andy
Charles Schuler wrote:>
Andy writes:
That makes sense. Since old rabbits will reproduce at a lower
frequency than younger rabbits, it is reasonable to expect that
old rabbit ears will pickup up VHF better than UHF......
I think you have it nailed !!!
L>))))))))) Andy
