Radio Control RF 433
Nowatiny
Sep 30, 2020
10
From the other receiver:
Receiver module :QA-R-011
Working Voltage: DC 3.6V~24V.
Maximum Load: 2A.
Static Current: 3.6 mA ~ 5.5mA.
Working Frequency: 433MHz.
Reception Sensitivity: ≥ -107dBm.
Modulation Mode:ASK (superheterodyne).
Number Of Stored Remote Controls: ≤ 10.
Working Mode: Momentary, Toggle, Latching Mode.
Learning Style: Learning Button.
Working Temperature: -20 degrees 80 degrees.
Appearance Size: 26mmx 13mm x 1mm (length × width × high).
Bertus
This mean that the Switch is not supported? I have to look for something else? What i should look for?
bertus
3,882
The other receiver can directly drive the ledlamp.
If you want to use the existing receiver, you will need a power driver:
The mosfet will easely be able to drive your ledlamp.
Bertus
