Rare Apple I computer sells for $216,000 in London
Charlie Gibbs
Yeah... You could say: "Okay, I don't really need to put in this
software fix. Only 40% of the paychecks will come out wrong, and
we can fix all that later..." :)
It's sad commentary (and probably warped my mind) that I would
welcome emergencies because it was the one time when I could
demand - and get - as much machine time as I needed.
Stan Barr
I had a Seikosha 9-pin dot-matrix printer (ca. 1990) that worked this
way. If your fanfold was 8.5 inches wide, you would set it left; if it
was 11 inches wide, set it right. You could set it anywhere in between
but there would be no reason to.
My old Star (which I still use) works that way. Does 132 cols too
with a compressed font.
The problem with using A4 paper is that some progams insist on
doing a FF by outputting a number of LFs to get to the bottom of the
page instead of issuing a FF, which the Star could handle correctly
for A4. The print would soon get out of alignment with the perfs.
I gave up on A4 fanfold for that reason.
Rod Speed
jmfbahciv wrote
Rod Speed wrote
Everyone can see that that is another lie.
So you are one of those people who believe that
withholding data and information gives you more power.
Nope, everyone can see from my usenet history that that is another lie.
I gave you the information. You want it in a different form ? Your problem.
<reams of your puerile shit any 2 year old could leave for dead flushed where it belongs>
Charles Richmond
The plain truth, Charlie, is that you the programmer get *no* respect:
For it's Tommy this, an' Tommy that, an' "Chuck him out, the brute!"
But it's "Saviour of 'is country" when the guns begin to shoot;"
| Charles and Francis Richmond |
| plano dot net at aquaporin4 dot com |
Rod Speed
jmfbahciv said:
Yea, I know. Yesterday was my last attempt. :-(
Great, there is only so much of your puerile shit anyone should have to put up with.
greenaum
Yes, the approach OS/2 took to not allowing dos apps to do anything they liked with the hardware
was certainly the way to go stability wise,
Don't see why, AIUI since the 386 all IO and memory access has been
virtualisable (there's some points in Scrabble!).
You don't need to really give them access, just let them try then
interrupt away to a handling / emulating routine. Tho I suppose that
routines need writing, and cycles to run in.
Then again AGAIN, if IBM hadn't done such a crappy job with their
BIOS, nobody would have needed to write straight to hardware. What did
DOS apps need anyway? A couple of K of text-mode screen RAM and maybe
a keyboard handler? Even VGA graphics is maybe 128K of RAM to store in
a buffer somewhere, and write to the screen using the appropriate
mechanisms the OS uses.
How much business software really needed low-level stuff? I suppose
some industrial control apps might have been delay-sensitive if they
were realtime. Still...
"hey let's educate the brutes, we know we are superior to them anyway,
just through genetics, we are gentically superior to the working
class. They are a shaved monkey. If we educate them, they will be able
to read instructions, turn up on time and man the conveyor belts,
sorted." #
greenaum
Sure they could. At the time, they could have provided the same sort of
encouragement to the clone manufacturers to preload OS/2 that MS did for
Windows.
[I realise this is a bit of an old thread, but... it's not like
Usenet's been busy. Hey, the old days are returning, but in the
opposite direction!].
As far as I know, from various sources including that famous one based
on the book in the late 90s, about the rise of Microsoft. That I can't
remember the name of...
What MS basically did, was give discounts to manufacturers and
retailers. You could have Windows at a significant discount, as long
as your business sells NO PCs with any alternative OS. For most
sellers, that's a fair percentage of a big amount of money.
So they stitched up the market and "leveraged", I believe it's called,
their small market advantage into a vast one. A company offering
alternative OSes would have this disadvantage against it's rivals, and
all other things being equal, go under. Thousands of businesses and
millions of customers manipulated.
This was (AFAIK IIRC ETC) the cause of one of the legal suits against
them. I remember at the time, Gates's moaning to the press about how
he was being picked on... "If the Federal Government demands I give
away 95% of my money to charity, I'll do it". As if that was one of
the government's powers, or a likely outcome to the case. He didn't
offer to run his business in a less predatory and monopolistic way, or
to stop buying up any company that looks like it might compete with
him, and either absorb or neglect it to death.
[All that money, and he STILL dresses like he ran through a charity
shop with a strong static charge].
The free market doesn't cope well with monopolies, and in the modern
age, businesses aren't happy with expansion any more. It's more
profitable to crush your rivals to cultivate as much as one can of a
monopoly, then charge what you like (or alternatively form a cartel
and price-fix everything), than it is to make a better mousetrap, and
rely on the consumer's own innate cannyness and wisdom to choose your
product above others, and.... all that other 1950s pipe dreaming
nonsense.
We're in the age of monopolies and megalopolies (whatever they are!).
Many corporations tower over governments in terms of cash and power,
and the simple blessing that is corruption, means politicians have to
compete for bribes with their fellows. Bribery's a seller's market
now. So you don't actually need to compete with a government, just to
fix it's minions.
As far as the 21st Century goes, I think it's probably a battle over
control of Google, with "Don't be evil" on the one side, and the
entirety of modern investment capitalism on the other. I dunno how
much control Larry and Sergey have retained thus far. Although
legally, being publically traded, they've an obligation to only do
things that make more money. It's illegal to be ethical if it costs a
stockholder a penny. An under-used defense in tax-fraud cases I feel.
sorted." #
Rod Speed
greenaum wrote
Don't see why,
Basically because you cant trap illegal behaviour
if apps can do anything they like with the hardware.
AIUI since the 386 all IO and memory access has been virtualisable
The OS doing hardware access that way is an entirely separate issue.
Not enough to matter, its not that uncommon a word in english.
try then interrupt away to a handling / emulating routine.
Not all direct hardware access involves interrupts.
Tho I suppose that routines need writing, and cycles to run in.
And is a lot harder to do when interrupts arent involved.
Win stopped using the bios LONG ago. Its basically just used in the boot phase now.
What did DOS apps need anyway? A couple of K of
text-mode screen RAM and maybe a keyboard handler?
Hell of a lot more than that with comms apps alone.
in a buffer somewhere, and write to the screen using
the appropriate mechanisms the OS uses.
Yes, but some hardware needs more than that.
Depends on what you call business software.
I suppose some industrial control apps might
have been delay-sensitive if they were realtime.
Yep.
Still...
There is no still with computer control of fancy equipment.
to read instructions, turn up on time and man the conveyor belts, sorted." #
You should preceed that sort of thing with just -- on a line by itself,
then the better usenet clients can strip it auto when replying.
Rod Speed
greenaum wrote
Not even possible. IBM never mattered a damn to
the PC industry once everyone ignored what they were
doing hardware wise with the PS/2 spectacular footshot.
You into necrophilia ? We'll hold our noses...
it's not like Usenet's been busy. Hey, the old
days are returning, but in the opposite direction!].
Nope, we're not into lobbing clay tablets at each other, yet.
famous one based on the book in the late 90s, about
the rise of Microsoft. That I can't remember the name of...
What MS basically did, was give discounts to manufacturers and retailers.
There was a hell of a lot more involved than just that.
They had both the OS and the apps that most wanted to use, so
there was a real sense in which the average buyer of hardware
demanded that the hardware had what they were used to on it.
And even the stupidest PC user found Win apps a lot easier
to use than DOS apps, if only because the user interface
was a lot more orthogonal across the apps they used much.
That wasnt even legal in many jurisdictions so
there much have been more involved than that.
And when their main competitor is quite literally free, and never
did see much market penetration at all, that cant fly anyway.
For most sellers, that's a fair percentage of a big amount of money.
Pity about when the OS ended up quite literally free.
it's called, their small market advantage into a vast one.
There was much more involved than that, most obviously with the workplace.
A company offering alternative OSes would have this
disadvantage against it's rivals, and all other things being equal,
They never are.
go under.
IBM didnt. Not even Digital Research did either.
Thousands of businesses and millions of customers manipulated.
Its an urban myth.
This was (AFAIK IIRC ETC) the cause of one of the legal suits against them.
The US legal system has been completely off the rails for centurys now.
I give away 95% of my money to charity, I'll do it". As if that was one
of the government's powers, or a likely outcome to the case. He didn't
It was never ever a monopoly. In spades when the main competitor is quite literally free.
or to stop buying up any company that looks like it might
compete with him, and either absorb or neglect it to death.
Odd that that didnt happen with IBM, or DR, or WordPervert etc etc etc.
Its just another urban myth/lie.
through a charity shop with a strong static charge].
Not anymore. Someone, presumably his wife, even eventually even got him to wear a suit.
and in the modern age, businesses aren't happy with expansion any more.
Oh bullshit. Google is very happy with expansion.
It's more profitable to crush your rivals to
cultivate as much as one can of a monopoly,
Not even possible when the main competitor is quite literally free.
And Gates never had a hope in hell of crushing IBM.
(or alternatively form a cartel and price-fix everything),
Not even possible for centurys now in the first world.
than it is to make a better mousetrap, and rely on the consumer's
own innate cannyness and wisdom to choose your product above
others, and.... all that other 1950s pipe dreaming nonsense.
Taint a pipe dream, its what MS, google, ebay, facebook, twitter, etc etc etc keep doing.
Pigs arse we are when the main alternative is quite literally free.
Try telling that to Gates. Dont be TOO surprised when he just laughs in your face.
politicians have to compete for bribes with their
fellows. Bribery's a seller's market now.
MS never bribed even a single politician.
So you don't actually need to compete with a government, just to fix it's minions.
Not even possible when the main alternative is quite literally free.
As far as the 21st Century goes, I think it's probably a battle over control of Google,
Nope. The market just heads off to shit like twitter and facebook.
It never works like that.
I dunno how much control Larry and Sergey have retained thus far.
Complete, actually.
Although legally, being publically traded, they've an
obligation to only do things that make more money.
Thats just plain wrong.
It's illegal to be ethical if it costs a stockholder a penny.
Thanks for that completely superfluous proof that you aint a lawyer.
Jasen Betts
should be "-- " on a line by itself, the space is important.
Charlie Gibbs
Bill Gates would repeatedly whine about how the government was
stifling Microsoft's right to innovate, while at the same time
Microsoft was stifling everyone else's right to innovate - or,
oftentimes, to exist at all.
Well, Donald Trump has the hair thing...
Yup. Which is why a psychological analysis of a corporation classifies
it as a psychopath.
http://siivola.org/monte/papers_grouped/uncopyrighted/Misc/corporate_psychopathy
..htm
Charlie Gibbs
It's not enough for an alternative to exist. Talk to your average
Windoze vict^H^H^H^Husers. They have been totally subjugated.
It's like people living in a dictatorship - the average joe can
do nothing about it, so he just shrugs his shoulders and gets on
with life as best he can. There is no alternative.
"In politics, perception is reality."
You really ought to read "Nineteen Eighty-Four" again.
Rod Speed
government was stifling Microsoft's right to innovate,
And that is precisely what the govt was attempting to do when it
proclaimed that MS couldnt include a free browser with their OS.
while at the same time Microsoft was stifling everyone else's right to innovate
Thats a lie. Didnt stiffle google, twitter, facebook, ebay, etc etc etc.
- or, oftentimes, to exist at all.
Never in fact.
Nope.
Which is why a psychological analysis of a corporation classifies it as a psychopath.
Mindlessly silly.
Rod Speed
The free alternative does a lot more than just exist.
Talk to your average Windoze vict^H^H^H^Husers.
Nope, they choose to use it. You dont approve ? Your problem.
Nothing like. They are free to run the free alternative if they want to.
- the average joe can do nothing about it,
Thats a lie. They can use the free alternative any time they like.
Corse there is an alternative. Some hardware even comes with it included.
We aint talking about politics.
No thanks, he fucked up completely. We never did get anything like that.
Peter Flass
Charlie Gibbs wrote
Not that they ever have innovated, of course, but they'd like to know
they could if they ever decided to.
You seem to have a rather one-sided view of the subject. It's been
proven that M$ used predatory pricing tactics to prevent anyone
preloading any other OS. By including their browser with their OS while
preventing any other browser from being preloaded they were pursuing
predatory tactics. They had the right to ship their browser on the same
terms as anyone else, but bot by illieally tying it to their OS monopoly.
Never in fact.
The only reason they didn't stifle these was because they didn't see
them coming. Otherwise they would have strangled these the same way
they did everyone else. I could make a long list of companies that they
forced out of business, to name a few: Lotus (though still in a zombie
state as part of IBM), WordPerfect, Digital Research, Novell, Borand,
etc. They managed to force even IBM to exit the PC OS business, even
though OS/2 was a great advancement on most of the M$ OSs that followed
it: Win 3.1, Win NT for several releases, Win 95, Win 98, etc.
Ahem A Rivet's Shot
On 22 Jan 2011 21:12:28 GMT
Indeed, DOS was not an innovation, it wasn't even orignally developed by
MS.
Furthermore it was originally close to a copy of CP/M.
Indeed, Windows was not an innnovation, just a ripoff of Xerox and
Apple. Networking in windows (remember Winsock?) derived from BSD.
Winsock wasn't from MS, it was put together by a group of people
chatting on Compuserve - MS never even implemented the first version of it
(that was left to Trumpet to do).
Network File Systems? First done by Novell with Netware.
I think DEC FAL was a bit earlier (ie. earlier than PCs).
Where's NetBUI today (an example of innovation gone bad)?
IE? First done by Mosiac, then Netscape.
IE and Netscape were originally derived from Mosaic.
I think we are in strong agreement about how little innovation has
come out of MS.
Rod Speed
Peter Flass wrote
Thats a lie. They clearly did with the browser, and with the
UI that even Linux has copied extensively now, and with
networking that even stupid users can use, etc etc etc.
but they'd like to know they could if they ever decided to.
You'll end up completely blind if you dont watch out.
Then you need to get your seems machinery seen to, BAD.
It's been> proven that M$ used predatory pricing tactics to prevent anyone preloading any other OS.
Clearly hasnt prevented those who preloaded something else.
By including their browser with their OS while preventing any other browser from being preloaded
Nothing to stop anyone preloading any other browser. Some did.
they were pursuing predatory tactics.
Another lie. Nothing to stop you loading any browser you like, and hordes do just that.
They had the right to ship their browser on the same terms as anyone else, but bot by illieally tying it to their OS
monopoly.
Nothing illegal about including a browser with the OS they supplied.
And there never ever was an OS monopoly either.
In spades when the main alternative OS is quite literally free.
The only reason they didn't stifle these was because they didn't see them coming.
Even if they had seen them coming, they couldnt possibly stiffle any of them.
Otherwise they would have strangled these the same way they did everyone else.
The clearly didnt strangle IBM or Linux or google.
I could make a long list of companies that they forced out of business,
No you cant.
That wasnt forced out of business by MS, they just fucked up very
spectularly and didnt keep up with what people wanted in a spreadsheet.
(though still in a zombie state as part of IBM),
So you lied when you claimed MS forced them out of business illegally.
WordPerfect, Digital Research, Novell, Borand, etc.
None of those were forced out of business except in the sense
of providing what the consumer preferred to use instead.
Pigs arse they did. IBM was stupid enough to go that route itself.
even though OS/2 was a great advancement on most of the M$ OSs that followed it: Win 3.1, Win NT for several releases,
The consumers clearly felt otherwise. You get to like that or lump it.
Rod Speed
Scott Lurndal wrote
Indeed, DOS was not an innovation, it wasn't even orignally developed by MS.
Indeed, Windows was not an innnovation, just a ripoff of Xerox and Apple.
Thats a lie, there was a lot more too the later Wins than anything Xerox had.
Apple didnt even have multitasking for quite a while.
Nope, not with networking that even stupid users could use.
Nothing like how Win networking ended up.
Quite a bit of the detail was nothing like either.
The Zune was not an innovation, nor was the Xbox, nor is their cloud.
Microsoft only innovates in monopolization techniques.
How odd that Linux has used so much of the UI seen with Win.
Anne & Lynn Wheeler
there was also datahub ... done by san jose ... but a lot of the
implementation was being done under subcontract with group in provo
.... there was somebody commuting from san jose to provo nearly every
week. when san jose decided not to follow thru with datahub ... they let
the group in provo retain all the work they had done.
