Kevin Weddle said:
Why don't they just say the 60Hz has all sorts of noise.
Hey Kevin,
I am not 100% sure that I am getting your question. As far as this quote is concerned maybe I can help a bit. When you are talking about the power grid in North America, the fundamental frequency of the power is 60hz. If you have a non-linear load (i.e. a rectifier) harmonics are created. Depending on the nature of the load, you will get different harmonics.
Here is an example:
If you have a fundamental frequency of 60hz feeding a 3 phase 6pulse rectifier. You will have 5th and 7th harmonics present, they will have frequencies of 300 and 420 Hz respectively.
If you try to tune a filter to 480 Hz, you will get rid of the 7th harmonic, however the waveform will still be distorted due to the 5th. If you could filter out all harmonics (which is very difficult and costly) you would see a pure sine wave at 60hz.
If you are passing a purely fundamental wave through an inductor or capacitor, ELI the ICE man has all of your answers.
When a circuit is inductive:
Voltage leads current.
When the circuit is capacitive:
Current leads voltage
