RCA 32V434 Dead set
Gary L. Woodruff
howdy, I have a RCA model# 32v434 that has no picture and no sound. I
have checked the fuse. When first plugged in you can hear a relay click
and if you press the power button the power light flashes on and off
until you unplug it. Any and all help is greatly appreciated.
Thanks, Gary
K
Ken
Thanks, Gary
I would suspect your set is going into an over current condition.
Check for a shorted component in the HV circuit for a start. If nothing
is found there, check for the same in the LV circuits. I trust you do
have the necessary instruments and knowledge?? If not, take it to
someone who does, it will be cheaper and safer in the long run.
Gary L. Woodruff
Meat said:
Do you have prior experience repairing anything 'electronic'?
Especially something that has lethal voltages inside?
Howdy all, Yes I am proficient with all test equipment. I am aware of
the proper procedure to discharge a flyback etc. I do not have a HV
probe. I have read the flyback and HOT are common failures in RCA's.
I do not have years of experience with TV's and have not repaired any in
15 years or more. I am looking for some general guidance or someone with
many years of TV repair that can SMELL whats wrong!
Thanks, Gary
