RCA 36V430T Chassis ITC008HYN turns on and off repeatedly.
Gary L. Woodruff
howdy, I have this monster RCA that is possessed. It will turn on and
then at random intervals will shut down and power back up. I have
touched up any solder connections that looked cold, and verified the
front panel switches are not shorted. I still have the problem. Any and
all help is greatly appreciated.
thanks, Gary
Leonard Caillouet
Gary L. Woodruff said:
howdy, I have this monster RCA that is possessed. It will turn on and then
at random intervals will shut down and power back up. I have touched up
any solder connections that looked cold, and verified the front panel
switches are not shorted. I still have the problem. Any and all help is
thanks, Gary
Verify that the plastic buttons are not touching the tact switches. You
might just change the tact switches anyway if it is not a mechanical problem
like this. These sets have lots of problems with intermittent operation due
to bad switches. They need not measure a short.
Leonard
ccurtis
Oct 27, 2009
thanks, Gary
I admit I am not at all familiar with that particular chassis, but I had a similar problem in an RCA TV and it was solved after replacing the metal encased tuner module.
Gary L. Woodruff
Leonard, Thanks for the tip. I have checked all of the switches for
shorts, all read open unless they are activated. i am testing with the
button panel out of the set so no buttons are are falsely activated. I
read somewhere that it could be the power IC but I do not yet have a
service manual to locate it.
Gary L. Woodruff
Leonard, I did not catch that the switches may not be shorted to cause
the problem. I have removed all of the tact switches from the panel and
am still getting power up & power down over and over ...... I believe
that eliminates the tact switches, do you have any other suggestions or
feel that the tact switch cb is faulty?? the set does not stay powered
up long enough to develop any rastor but does seem to generate hv (not
measured but get alot of static on th pt). Any and all help is GREATLY
appreciated
