RCA 60inch Flyback transformer
Ted Machcinski
Hi The flyback seems to have gone on my RCA 60 inch TV Model P60928.
Any one know of a good place to get a replacement? Also anyone know
how to get the HV lead out of the High Voltage spliter. Thanks Ted
Ricky Eck
You may try here, I got a flyback at a reasonable price, and they shipped
quickly. But you will need the actual part number (Should be on the flyback
it's self). Also, do a search on the net for the part number. That is how
I found mine. Others may have a better place then this one, but it is a
start.
http://www.electronix.com/catalog/
David
"seems" to have gone out? How are you sure?
There are lots of other more common failures in the HV and deflection
circuit other than the flyback.
The HV lead has a retainer and a little plastic clip on the hv splitter,
simply pry the clip back (without breaking it) and pull the lead out with
the plastic sleeve. If the hv grommet did not come out use a bent paper
clip to pull it out.
David
Art
May want to try changing the HV slpitter also, it may have caused the
original problem.
John Del
Subject: Re: RCA 60inch Flyback transformer
the plastic sleeve.
While the OP didn't post the chassis series, I believe he has the later PTK195,
which uses a twist and yank method of removing the wire.
John Del
Wolcott, CT
"I'm just trying to get into heaven, I'm not running for Jesus!"
Homer Simpson
(remove S for email reply)
techforce
I can supply both the FBT and the Splitter. Post your request here and I
will contact you directly.
http://www.technotronic-dimensions.com/supportbbs/index.php
Ted Machcinski
Thanks for the help everyone. Chassis is a PTK195NT. I have a Flyback
ordered. Flyback looks like it was arcing near the top. Will find out
when the replacemet arives. Thanks Ted
Danny
Ted,
The flyback is the most common problem with that chassis and we
replace about 4 per month here in my shop. Yes all the bad flys arc at
the top. The Horizontal Output Transistor usually goes out too. the
RCA part # for the fly is 239111. The HOT is 237470.
danny
DSElectronics.com
Jason D.
Ted,
danny
DSElectronics.com
Funny, I just got a PTK195 done for estimate today! (for 46" base
model) chassis with fried 239111 and a shorted hot. Currently waiting
for OK on estimate.
Cheers,
Wizard
Ted Machcinski
Thanks for the help everyone. Bad flyback and HOT. Working great now. Ted
