RCA CTC177
V
Vince
Hi!
All th channels are fine up to and including 32 then nothing until you get
to 51, I did the solder job but it did no good. Any ideas.
Vince
H
hr(bob) [email protected]
Hi!
Vince
Are you using cable or on the air signals to test?
H. R.(Bob) Hofmann
Hi!
Vince
I thought that problem sounded like something I had run into before. I
went back to my old fixfindr program & came up with this, measured 15V
at U7501 pin 14, but 0.34 at CR7108. R7514 checked good in
circuit,but the 15V drop was across it. bridging another 100K across
R7514 restored normal voltage at CR7108& normal tuning Hope this
helps C harles
Tom Del Rosso
helps C harles
Why not the common problem of corrupted EEPROM?
