RCA CTC177
V
Vince
Hi!
I have this 177chzssis that has a good picture on all the channels except 14
to 18 and 34 to51, I did the solder job but it didn't do any good, what else
can I do?
Thank youi
Vince
Tom Del Rosso
Vince said:
Hi!
except 14 to 18 and 34 to51, I did the solder job but it didn't do
any good, what else can I do?
Thank youi
Vince
Did you read the voluminous material in the faq?
I don't understand why no one mentioned the EEPROM. I must be wrong, but I
thought your symptom was due to the channel preset data getting corrupted.
Sofie
Yes....based on the original symptoms corrupted data in the EPROM is
certainly suspect BUT the grounds connections resoldering in and around the
OBT (on board tuner) is a very FIRST procedure so if the EPROM is replaced,
the new one won't get corrupted. A full tuner alignment must be done or if
good EPROM data cam be downloaded with the Chipper Checker the job will be
much easier and less time consuming.
Yes... there is "voluminous" and very good material in the FAQ.
Dan
Tom Del Rosso
around the OBT (on board tuner) is a very FIRST procedure so if the
EPROM is replaced, the new one won't get corrupted. A full tuner
alignment must be done or if good EPROM data cam be downloaded with
the Chipper Checker the job will be much easier and less time
consuming.
Dan
Thanks. I know the soldering must be done first, but I didn't mention that
because he already did that part.
Sofie
Tom Del Rosso:
I knew that you knew about the soldering being done first... and, like you,
I am surprised that no one mentioned a corrupted EPROM......
......I stated the obvious for the benefit of the OP.
Daniel Sofie
Electronics Supply & Repair
snipped:
