RDS level 2KHz, deviation +- 75KHz.
Boki
Hi All,
I have a specification on my FM TX,
Question:
1. If my FM TX freq is 100MHz, where is the RDS freq ?
2. The deviation means when RDS is trasmitting ( and keep trasmitting
data repeat), I check the tone deviation of RDS?
Thank you so much!
Best regards,
Boki.
martin griffith
Hi All,
Question:
Thank you so much!
Best regards,
Boki.
try radio newsgroups, such as rec.radio.broadcasting
martin
Joerg
Hello Boki,
Question:
AFAIK it rides on a 57kHz subcarrier.
Thank you so much!
Best would be to read up on the spec:
http://www.rds.org.uk/rds98/rds98.htm
Question:
I have read the spec and implemented a sw-side receiver -> webb app.
Anyway asfair, RDS data is sent at 57 kHz just like the sound is sent at
<19 kHz. A simple way to get to the data is to get the baseband signal
connected to an RDS chip from philips which will give you data+clock asfair.
