Re: can I change the output frequency of my fm transmitter?
nxt02
Jul 4, 2009
13
u can change the antenna windings by amount size and you can also change the thickness of the wire used. or add a variable capacitor across the antenna. hope that helps  :-\
audioguru2
Apr 6, 2004
12,026
Adding a variable capacitor across the antenna will not change the frequency.
The circuit probably uses a modern frequency synthesizer circuit with a quartz crystal and phase-locked-loop. Maybe the crystal can be replaced with one having a higher frequency. The existing crystal might be 6.2MHz. Try a 7.6MHz crystal.
