That won't work, you need to measure the DC current flowing though the co-ax, not just the voltage.
You need to break the shield and wire the resistor in series. The break and the resistor need to be as small as possible to avoid ruining the properties of the transmission line.
I'd recommend a low inductance thin metal film surface mount resistor. I'd also recommend adding a filter capacitor and possibly ferrite beads to the input of the amplifier, op-amps aren't designed to work at these sorts of frequencies and might do funny things when exposed to an 18GHz signal.
