Re: high voltage meter problem
steven2
Jan 19, 2004
1,698
high voltage resister devider  100 time ten m resistors in sieries and hv goes in one end and you measure the output voltage across your meter set to 600 volts  if it reads say 113 its 11300 volts dc
Hero999
Oct 28, 2007
2,433
The meter will have an impedance of 10M so to divide by 10, all you need to do is connect a 90M high voltage resistor in series with it. This can be made using nine 10M resistors in series, each resistor needs to be rated to 1/10th of voltage being measured.
