Re-join 3x 1.5mm2 cable
camilozk
Apr 20, 2014
122
hi!
what is the preffered method to re-join a 3x 1.5mm2 cable?
I understand you cannot solder it since it could get hot and melt.
thanks!
camilozk
Apr 20, 2014
122
thanks!
I thought that soldering the joint / splice was not recommended as it could get hot and melt. what about that?
kellys_eye
Jun 25, 2010
6,512
'Join' under what circumstances?
Indoors, outdoors, fixed, flexible ?
Inline crimps, chock block, resin-set, terminal box? twist,solder, heat-shrink?
Soldering is acceptable under some circumstances and won't melt if the conditions are met.
camilozk
Apr 20, 2014
122
thanks kelly for participating. outdoors and flexible: what is the preffered method to re-join a 3x 1.5mm2 cable?
hevans1944
Hop - AC8NS
Jun 21, 2012
4,986
Depends on what kind of wire the cable is made from. Aluminum cannot be soldered but can be welded under a tungsten inert gas shield (TIG welding). Copper is easily soldered without melting the copper. Both metals can be joined by mechanical pressure fittings, although copper-to-aluminum joints are subject to electrolytic corrosion because of the dissimilar metals.
14,487
hi!
thanks!
since you have given absolutely no info on the actual cable type
everyone is just guessing
PLEASE show photos of the cable
maybe even a link to a datasheet for the cable
Everyone else please wait till this info is supplied
