read/write in memory card with microcontroller
Gregory
I would like to use a memory card (SD for example) to exchange data between
a PC and a microcontroller or cpld.
I haven't yet choosen a specific type of card or microcontroller/cpld
The size of memory needed is only 32K, there is no speed constraint.
What could be the best type of memory card to do this easily?
Where can I find samples of code and schematics for:
read/write beetween card and microcontroller/cpld ?
read/write beetween PC and card ?
Gregory
Roger Hamlett
Gregory said:
between
Use a CF/MMC card. These have about the simplest interface to implement
(there are actually two interface modes, with one being like IDE, and the
other a simpler but slower synchronous serial interface).
Elector magazine, did an article, with a circuit, and software for this,
and dozens of similar interfaces are available for other micros (8051,
Atmel, PIC etc.). Remember that to 'exchange data beween a PC and a
microcontroller', the microcontroller, is going to have to handle the FAT
filesystem, not just write the card as if it was a lump of memory. This
will involve a significant amount of software, even if you limit it to a
'subset' file system, perhaps only supporting FAT12. With this in mid,
there are small interfaces on the market, offering a serial interface to
this, with the file system support already included, and there are similar
modules to handle USB memory cards, which might well be a very 'easy'
option. The Vinculum VDRIVE module for example, support async serial, or
SPI interfacing, to a USB memory card.
Best Wishes
Adrian Jansen
Gregory said:
Gregory
This link might give you some ideas:
http://www.mcselec.com/index2.php?option=com_forum&Itemid=59&page=viewforum&f=9
Regards,
Adrian Jansen adrianjansen at internode dot on dot net
Design Engineer J & K Micro Systems
Microcomputer solutions for industrial control
Note reply address is invalid, convert address above to machine form.
