Reading a ruler help, 1.2 or 1.02
computer-joe
Oct 6, 2016
29
help! i need some ruler help,
Im making a project on photo shop. I had to measure a paper cover i own
it measures 1.something by 1.something
i need to put that in photoshop, but the problem is i don't know the correct reading.
Would it be 1.02 or 1.20
here is a picture of that
dorke
Jun 20, 2015
2,342
Well,
Since you asked,(it is quite obvious to most people),
here is a simple way to deal with these kind of linear scales:
Each CM(biggest bars) is divided into 10 equally spaced smaller bars with one medium sized one in the middle.
It should be interpreted like so:
Each small bar is 1/10 of a CM (0.1CM).
The mid bar is 0.5CM.
That would work for all types of linear scales.
People used to CM scales take that(decimal system 1/10) to be an obvious thing.
When they switch to Inches they have a problem understanding the power of 2 system(1/2,1/4 1/8,1/16 etc.)
Isn't it about time to throw away that ridiculous inch system ?
Who in the world still uses it ,(USA and...)?
Apart from the difficulty of switching ,why ?
Ah yes, but, it's quicker to say "knock off an extra thou" than it is to say" knock off an extra zero point zero two five millimetres". :p
Edit: for the machinists out there ....:)
hevans1944
Hop - AC8NS
Jun 21, 2012
4,978
Yeah, I have trouble even seeing those itsy bitsy teeny weeny marks on a steel scale that is marked off in 1/64" increments. And it seemingly gets worse when that inch scale is only divided into fifty linear increments instead of sixty-four. I usually keep a set of vernier calipers with a dial indicator or a digital readout handy to verify that I've read the scale correctly.
