Reading USB camera data from a microcontroller
I
Ivan Nathvalski
Can some USB, microcontroller expert advise me how can a USB webcam be
interfaced with a microcontroller (PIC, ATMega, etc) so that we can capture
image frames (low speed, low res) with the microcontroller?
mark jb
capture image frames (low speed, low res) with the microcontroller?
you'd need a usb host on the board to interface with the micro, power to run
the cam from the board... you may be better ripping a cheap cam apart and
pulling a direct video output before the usb out (if possible)
-mark
H
Hans-Bernhard Broeker
About as well as you could pull a 20-ton cargo trailer up a hill using
a bicycle. You need a USB host for that, which needs between one and
two orders of magnitude more CPU power than what you're envisioning.
Michael J. Noone
Cypress makes some nice little USB host chips - I'd reccomend taking a
look at those as I doubt a 8b micro could handle the complexities of a
USB host interface. Best of luck!
-M. Noone
Alex Gibson
Go with an older type serial cam or get a camucam2 or avr cam
or similar.
http://www.cs.cmu.edu/~cmucam/
http://www.jrobot.net/
http://home.teleport.ch/idobson/ using bascom avr
http://home.teleport.ch/idobson/projects/UDP-webcam.htm
http://home.teleport.ch/idobson/start_e.htm
Alex
dmm
Not a USB solution, but John Orlando and Brent Taylor won 2nd prize
in Circuit Cellar's AVR contest last year with an ATmega8 controlled camera.
http://www.circuitcellar.com/avr2004/Second.html
Rudolf Ladyzhenskii
USB is a master-slave system. Camera is a slave, so you need a master (USB
host). Low-end micros with USB are USB slaves too.
You need a USB host. It is either built into the higher-end processors or
you need external chip. But this is only half a problem. Then you need USB
host stack, typically found in larger OS, like Linux.
Rudolf
D. Jay Newman
I'm solving this problem with a Linksys NSLU2 (Network storage system).
This device has one ethernet port, two USB host, and 1.5 serial ports.
You can load a version of Linux on it that will handle a webcam.
I am planning on preporoccesing the image there and then passing on
the relevent information to my main processor.
http://www.nslu2-linux.org/wiki/
