Sunny
- Jan 1, 1970
- 0
I recently purchased a new work boat with a manual start 30hp 4-stroke
outboard motor. I need to install running lights, and would like to
avoid using a battery.
The outboard has two unused wires leading from a stator coil under the
flywheel which I'm pretty sure would be used for the battery charging
circuit on the electric start model. The owner's manual does not include
a wiring diagram, or other relevant information, but I expect I would
find crude AC - varying in voltage with engine RPM? - on these two
wires. I'm hoping I can rectify and regulate the stator output to 12v DC
to power the running lights.
My initial idea was to use a bridge rectifier and filter capacitor,
followed by a fixed voltage regulator. I salvaged an 8A 50V bridge
rectifier and 10,000uF 50V electrolytic from a dead PC monitor which
should handle the DC conversion, but the only 12v linear regulators
available locally are 7812s which are limited to 1.5A - not quite
enough. An LT1084-12 (5A) would probably be ideal, but is not easily
available to me.
I could possibly use a 7812 with a power transistor bypass to increase
ampacity, but I'm not confident when it comes to selecting a suitable
transistor and associated resistors given the variable (and unknown)
input voltage.
Given the application I would like to keep it minimal and robust.
Perhaps someone has already encountered this problem and designed a
simple solution using commonly available parts?
TIA
Sunny
available to me.
input voltage.
TIA
Sunny
