Rectifying an audio signal
Gandy
Dec 6, 2012
7
Hello all, this is my first post. I'm examining the electronics of dynamic range compressors, and I can get most of the steps in the signal flow easily except the very first.
I'm trying to rectify an unbalanced AC signal (the audio signal) so both the positive and negative waves are positive, i.e. I have to flip the negative's phase and combine the positive and negative so I essentially get an unsmoothed DC signal.
I know this is easily done with a transformer balanced signal, but I'm trying to do this passively without a transformer – I just can't get my head around how I flip the negative signal so it's positive after splitting it with a pair of diodes, if it can even be done like this.
Can anybody offer any help?
Thanks very much.
14,315
Build an OpAmp based rectifier. That will eliminate the voltage drop across the diodes which will otherwise significantly distort the rectified signal.
Harald
duke37
Jan 9, 2011
5,364
Horowitz and Hill (p120 in my 1980 copy) give details of two absolute value circuits if you need something more fancy. I could sketch these out if you wish, the book will not fit on my scanner.
Raven Luni
Oct 15, 2011
798
What a lovely little circuit. I wish I had known about this before.
