Relay with small in size
That could be difficult to achieve given one has to consider the physical constraints when operating at mains potential.
Minder
Apr 24, 2015
3,560
That is a DIP size spaced format complies with 2.54mm, do you need the same?
Those are available quite cheap, AliExpress etc.
M.
wounder
Jun 15, 2019
13
Yes.. Dip size format.. Instead of this relay needed a smaller one.
Minder
Apr 24, 2015
3,560
If you go to Digikey site, you should find all you need, this is a smaller footprint, 399-11052-5-ND.
Do you actually need DIP spacing format.?
M.
