Remote control not powering on! Help me please!
DroneFisherMan
Sep 19, 2018
Hi All,
i am using bayangtoys X16 GPS drone.
I managed to solder the "alfa APA-M04 7 dBi gain RP-SMA directional panel antenna Wi-Fi" on the board, and it was working absolutely fine. Until, I put hot glue on the antenna's solder to make it more solid.
Since then , when I power on the remote the red light comes on for a second and beeps then it goes off. I removed the hot glue and still its doing same thing..
Have I burnt the Tx?
I have checked for any short on the antenna's ground and main wire, there is no short there. I have checked the battery and power, and all looks good.
Could anyone help me out please!
DroneFisherMan
Sep 19, 2018
the power does come up but then goes away, if I immediately power it off and power back on, then there is no LED,
However, if I pause for 5-10 seconds the intensity of LED is high, and subsequently low if powered on during less intervals.
bigkim100
Apr 17, 2013
270
I would suggest that you may have cooked the Bayang toys transmitter. Remove the added cicuit , and see if it works then...if not , you have cooked it. You would probibly do better using a cheap wireless wi-fi repeater.
