remote control using radio freq
keile
Jul 1, 2004
36
hello!
Our project has been approved and now we need to build our prototype.
As I research, our project is basically a radio controlled device. Push a button in the transmitter side and when it was received by the receiver it buzz or light.
I know it is quite simple compared to examples shown in sites. ???
Now I don't know how and where to get started. I'm thinking of using pulse modulation to send commands. Command to light or sound.
Thanks in advance ;)
Note: I'm fairly new in practical electronics. As I have already studied
theories.. I think I can learn well.
trigger
Aug 7, 2004
236
Think of the followings:
1. Transmit distance
2. Transmit frequency
3. Transmit modulation (AM, FM, etc)
4. Bandwidth/ data rate of the commands
Hope these give you some insight... ;D
keile
Jul 1, 2004
36
to MP
wow! that's one hell of an amazing device!! honestly, if I look and examine its every detail, its perfect for my project. With its security and features.. wow.. but the 433Mhz chip cost around $54 uhh.. but a whola thanks!!
to trigger
this is what I have tentatively decided:
minimum of 10m
around 2.45Ghz *same as bluetooth
PM (Pulse Modulation)
uhh.. i still don't have an idea
thanks! ill update to find more circuits :)
trigger
Aug 7, 2004
236
2.4GHz ISM band is a bit difficult for me esp. to build transmitter, because it involves a lot of matching problem.
Although you can build using simple LC+transistor circuit but if you don't have a spectrum analyzer or signal generator, it will not an easy job.
For me, I will start with 433.92MHz where it is simple and need lesser equipments esp. you can build a transmitter using saw resonator and a transistor based receiver.
keile
Jul 1, 2004
36
oh so a higher frequency has lots of difficulty in terms of building a transmitter...
do you have any idea how can i avoid interference if I use a lower frequency like 433Mhz? ???
trigger
Aug 7, 2004
236
higher frequency will have more interference esp. 2.4GHz band......
like microwave oven, DECT phone, wireless lan, Bluetooth etc.
For 433MHz, I think if you are in UK, the most problem will be caused by the TETRA (police RF communication ?? not sure, it is at 426MHz). You have to build a narrow band receiver to prevent jamming from it.
MP1
Dec 7, 2003
3,399
Keile,
You need to find a better place to shop for parts. You can get this whole kit for $40 or just the module for $13. This is a kit from electronickits.com
The exact link for these parts or the kit is here:
http://www.electronickits.com/kit/complete/elec/ck1616.htm
Hope it helps you along on your project.
MP
keile
Jul 1, 2004
36
hello I'm back! :)
btw, before I continue on.. I would like to give a lotta of thanks for trigger and MP for helping me on this project.. thanks a lot!!
Something strikes me while listening to my instructor bout 555 timer. And this what I think how my circuit should be (below)
and now i think there's a problem.. the two signals might not synchronize each other.. one might be low and one might be high.. i have to ditched the comparator i think..
my goal is to use PWM(pulse width modulation).. so i think the receiver would check the width of the pulse rather than compare it with the (same pulse width)--needs synchronization.. if there's only a way to measure the width of the pulse..
thanks in advance.. actually i'm happy if I could build the circuit by myself.. :)
trigger
Aug 7, 2004
236
hmm......... you can use tone detector IC (LM567 ) after reciever for such application which will lower the complexity of building the comparator.
I haven't build circuits with this IC but I do think it may fit your needs.
keile
Jul 1, 2004
36
thanks trigger! :)
i have researched on the tone detector IC LM567 and found it.. uhh.. confusing ???
well, i have decided to take a look at my electronics book if I could find anything that would help my project. Phased-Locked Loop interest me. After reading all the explanation in the book plus a tutorial on the net, I found that this what I'm looking for, the PLL!!
Phase-Locked Loop (PLL) is an IC that synchronize two signals and output a voltage proportional to the phase and frequency of the input and self-generated frequency.
PLL IC's come in form of NE566, LM566, NE565 and LM565... I just noticed a similarities... LM567 is also a PLL! hehe.. sorry I'm so dumb to realize it sooner. Thanks again trigger!
I'll be back to post a circuit of my design. :)
trigger
Aug 7, 2004
236
Check this link for some useful circuit
http://members.shaw.ca/roma/seventeen.html
keile
Jul 1, 2004
36
wow! trigger I can't believe it!! You actually found it! :) oh thanks a lot!!
it's so similar that it only needs few customization or maybe not? hehe.. thanks again!!
trigger
Aug 7, 2004
236
You are welcome.
I just found the site yesterday where some of the circuits inside are useful to me too ;D
keile
Jul 1, 2004
36
hello!
so far this is the flow of my circuit:
555 timer(information,encoder) -> fm transmitter(carrier, modulator) ~~~
~~~ fm receiver(demodulator) -> PLL (decoder) -> output
i'm now in the process of testing transmitters and receivers..
i' ve come across this very nice fm transmitter: http://tacashi.tripod.com/elctrncs/smplfmtr/smplfmtr.htm
i'm planning to supply my transmitter and its receiver at 3 volts.
is there any 3v fm receiver that is simple enough for my project? Thanks!!!
trigger
Aug 7, 2004
236
Good to hear you have good progress ;D
And for FM receiver, you can try to use simple FM radio receiver ICs. They are served you well (for which your FM transmitter is within the broadcast band 88~108MHz)
ICs like TDA7000, TDA7088, MC3361, MC3362 may fit your needs..
Hope this help.
keile
Jul 1, 2004
36
yeah.. hopefully we can make a fully working prototype by next week..
I checked TDA7000 and TDA7088 IC's and looks like they're a complete fm receiver with no amp..
and I assume MC3361 and MC3362 is the amp right?
I wanted to run my receiver with 1.5V battery to reduce weight and I think these components would serve my needs..
As always, many thanks to trigger for your continuous support and help for my design project. May god bless you on your way :)
thanks,
keile
