Remote Controls not working ( Help Please )
Z
Zach
Hi I have a Panasonic Plasma TV, a DVD Recorder, and DVD Player.
Everything has worked fine, but tonight my remote controls failed to work.
At first I thought is was the batteries, but still not working.
Then I realized that no remote controls were working, TV-DVD-DVD Recorder.
Feels like some interference in our apartment or something ??
Anyone know what may be causing this ?
Any help much appreciated.
Cheers, Zach
Alan Rutlidge
Cheers, Zach
Welcome to the Twilight Zone. :p
John Tserkezis
If they all went at the same time, it's something environmental within the
room (or shining through windows). Not likely to be equipment fault, as
you've had several failures all at the same time (and the chance of that
happening is quite slim).
Have you installed a compact fluorescent light in the same room?
You can't see it (the human eye slows things down too far) but they flash,
or at least pulsate bright enough, and at a frequency that swamps the IR
receivers of all your boxes.
In effect, your TV, VCR etc are 'blinded' by the light.
Yes, yes, I've read that some people have not been affected by this, but
they're special cases, and just plain lucky.
Another option is that while the IR receivers are reasonably good at
filtering out ambient light, they're not infallible. Have you removed
curtains and are having bright sun shine on the boxes?
This is a less likely possibility, but you don't mention what changes were made.
If not either of those, under what conditions does it fail?
Sunlight or night or both?
Lights on or off or both?
What other changes where made within the room (even windows or curtains) in
the day of the failure?
Poxy
work. At first I thought is was the batteries, but still not working.
Recorder.
Chuck out those CFLs you just put in.
Z
Zach
Whats CFL's ???, anyway very wierd I went down this morning, and still the
same.
I moved my TV Stand forward to checkout behind tyhe mess of wires and stuff,
and suddenly everything started working again.
Very wierd, I still wonder what may have caused this.
My wife just told me that she has had this problem before, but just short
times.
I live in an apartment, could it have been something in my nextdoor
neighbours unit causing this ???
But anyway just again what are CFL's ?? as if I have them i will get rid of
them.
Thanks kindly.
Paul
Cheers, Zach
It could be that one of your remotes is working continuously, possibly
due to a button stuck down, and that is interfering with all the IR
receivers in the room.
Just my thoughts.
Phil Allison
"Zach"
** Loss of AC power to the items will mean that nothing works.
Even remotes.
........ Phil
Robbo
Rudolf said:
Hide all of the remotes (block the beam from them) and then try operate
one at a time.
Rudolf
stage fright....... ; )
Dorfus Dippintush
Frank said:
Go to google type in
how to test a remote
$B$I$N$G$O$
Results 1 - 10 of about 144,000,000 for how to test a remote. (0.21 seconds)
how about #1
MacGyver Tip: Test your remote's batteries with a digital camera ...
Another way to test a funky remote is to use an AM radio. Just tune the
radio to a station full of static, point the remote at the antenna and press
the ...
lifehacker.com/software/macgyver-tip/test-your-remotes-batteries-with-a-digi
tal-camera-280431.php - 46k - Cached - Similar pages
http://lifehacker.com/software/macgyver-tip/test-your-remotes-batteries-with
-a-digital-camera-280431.php
as they say "enjoy"
Cheers, Zach
Twice I have repaired mine by replacing the ceramic crystal on the
circuit board on the remote. If you drop it, the crystal breaks because
it's very fragile. Open up the remote, replace the little square thing
with two leads and try it out. The crystals are a fairly standard
frequency and cost about a dollar. Test it by putting it near an off
tuned AM radio and you should hear funny noises as you press the button.
Try a the radio trick with a working remote so you know what to expect.
Dorfus
Phil Allison
Frank said:
*$* If the AC power is lost, how come his computer still works so he can
make a posting here
** Lost only to the AV gear -
you steaming great Kiwi FUCKWIT !!!
...... Phil
eddie
did you place something infront of all your appliances?
did you install a new CFL
did you change / add / move something before all your remotes died?
Brian g
your English goes to the dogs when you loose a argument mate
****Er,so does yours,from both a grammar and spelling viewpoint!!
Brian G.
