Removed anode from my SCR
jackorocko
Apr 4, 2010
1,284
Why would they cut off the anode pin on a SCR? Would make sense if the tab was electrically connected to the anode, but I looked at the datasheet and I didn't see where it stated this.
http://cs.utsource.net/goods_files/pdf/22/22042_STMICROELECTRONICS_BTW69N1200.pdf
edit: well the MM reassures me that my assumption the tab is electrically connected to the anode is true. The SCR is rated for 200V, wouldn't it be a pretty dumb idea to charge a heatsink to 200V??? Seems like when they cut off the anode, they limited the scope of this SCR to 40V or less to keep it rather safe.
14,484
If you look at the datasheet, top of page 3
you will see that there 2 versions BTW69 - insulated and BTW69N uninsulated
If you have the xxx69N version then the anode is connected to the tab and the tab will be soldered/bolted to the PCB for both heatsinking and anode operation :)
