Renewable Energy (part 2)
davez
Oct 11, 2014
27
Hi guys Im creating another wind turbine generator do you have sample projects that you made yourselves? because Im having a hard time finding a schematic diagram for a wind turbine generator.
davez
Oct 11, 2014
27
What motor should i use for me to charge a 12v battery?
You will probably need a motor that operates from greater than 12V. Also, since wind turbines are generally low RPM, you will either need a gearbox or to rewind the motor to generate higher power at low RPM.
davez
Oct 11, 2014
27
:confused: rewind?? so i need to find a motor that is 12v higher?
Or you could use a boost converter if you get less than 12V from the turbine.
MPPT can also be used with wind turbines
Externet
Aug 24, 2009
944
What voltage and amperage are you aiming to ? For what purpose ? Charging an automotive battery ?
Find a discarded thread mill and use its permanent magnet DC motor as generator. Run it at the highest rpm you can.
