reparing Receiver - TX-8511
Xray
Jun 8, 2013
Hi
My receiver has 2 Speakers outputs A and B.
A speakers stopped working, so i changed to B, now it is gone too.
I wanted to try to repair it, any one can give some help on this issue? is it an easy fix?
thx
duke37
Jan 9, 2011
5,364
If the A speakers worked OK, then failed and the B speakers worked for a while, it is unlikely to be a fault in the electronics.
I would think it is a dirty switch. Spray with switch cleaner or wash with isopropyl alcohol.
Xray
Jun 8, 2013
it started to work again. I played with the back switch (4 - 8 ohm switch)
once i changed it, the amp started to work again in both positions. Bizarre, how can it fix itself like that?
KrisBlueNZ
Sadly passed away in 2015
Nov 28, 2011
8,393
Didn't you read duke37's reply?
As he said, it could a dirty switch. Or maybe dry joints on a switch. Could be the A/B switch or the 4/8-ohm switch, or both.
To find out which, put a continuous signal through the amp and tap or gently push each switch in various directions, to see whether one of them is intermittent.
Or open it up, inspect for dry joints, and clean the switches as duke37 described.
duke37
Jan 9, 2011
5,364
The technique of electronics repair is knowing just where to hit it.:):)
14,485
.... and what with ..... the good old fashion "micro-adjuster" aka a large hammer haha
sorry, couldnt resist
