Replacing a power source on a Gateway computer
Hi, I am attempting to replace the power source on my Gateway computer.
The computer is a desktop and is about 4 years old. I had help
finding the correct part to order but am trying to replace it myself
but don't know much about computers. I got the new power source into my
computer but I'm having trouble getting all the cables reconnected
correctly. Can anyone help me with this? Any advice would be
appreciated! Thanks!
reqluq
Then get help replacing it
correctly.
You should have asked before you removed the old one, someone for sure would
have told you to write down or better still; take a pic of the old one's
connections.
Can anyone help me with this? Any advice would be appreciated! Thanks!
As I said before get someone to come and help you put it back. Or call
gateway, or google your butt off and hope
req
Charles Schuler
http://www.fonerbooks.com/r_power.htm
http://www.helpwithpcs.com/courses/power-supply-basics-inc-pinouts.htm
Michael Kennedy
Honestly replacing a power supply in a computer is not a difficult
procedure. The only connector you have to worry about plugging in the wrong
way is the one for the floppy drive, but it is simple enough to see if it is
correct if you plug it in outside the case.
Just remember that every drive in your computer requires a power wire and
the motherboard either needs 1 or 2 connectores which are difficult to plug
in the wrong way.
- Mike
H
Homer J Simpson
BE CAREFUL! Some of the power supplies are all too easy to connect
incorrectly. If you don't know, look up the motherboard online, and cross
check it with the power supply.
Michael Kennedy
Well I guess thats definately true when it comes to the old AT power
supplies. Even though it was easy to connect them backwards they were also
really easy to remember which wire went where though. All you had to do was
put the grounds in the middle.
