Replacing NiCd camcorder battery with NiMH
H
Happy Friar
I everyone
I would like to replace the NP77H NiCd battery on my Sony analogue
camcorder with a suitable NiMH one. The battery supplier says thier
NiMH batteries are fully compatible with the original battery and
charge. However Sony say that I should not use a NiMH battery and
should replace it with another NiCd. Does anyone have experience of
this.
Regards David Parkes
DBLEXPOSURE
Happy Friar said:
I everyone
this.
I belive it boils down to the chargers capabilities. If it is not
compatable with NiMH then do not do it. Perhaps you can find a third party
charger that can. If Sony says there carger cannot do NiMH then I would
belive them.
http://e-parts.netfirms.com
H
Happy Friar
Thanks for the reply. Sony did not actually say the charger would not
do it they were more interested in selling me one of thier batteries.
If I do decide to buy a new NiCd then it will not be a sony but a
compatible one. My camcorder is 13 years old and does not see much use
but is usefull at times. So what is the difference between charging
NiCD and NiMH.
PeteS
The charge profiles are somewhat different.
NiCd charge profile:
Constant current, usually time limited. Trickle charge ok. Advanced
chargers measure temperature and cell voltage and cut the charge to
trickle during the -dv/dt part of the profile. Peak voltage is not
usually an issue (because the peak voltage can vary so widely for NiCd)
NiMH Profile:
Constant current or current limited (fast charge mode). Peak voltage
detection required. Trickle charge ok. Charge controllers should
measure -dv/dt and temperature.
In general, most available charge controllers for these types of
battery handle both (NiCd / NiMH). (See, for example,
http://focus.ti.com/paramsearch/doc...aramTable=yes&sortOption=&sortMode=&pageId=64)
You may find it difficult to get new NiCd (or you'll pay a premium)
because of their chemical content (heavy pollution issues). I would try
and find out if your charger is NiMH compatible.
Cheers
Petes
Robert Nichols
:Thanks for the reply. Sony did not actually say the charger would not
:do it they were more interested in selling me one of thier batteries.
:If I do decide to buy a new NiCd then it will not be a sony but a
:compatible one. My camcorder is 13 years old and does not see much use
:but is usefull at times. So what is the difference between charging
:NiCD and NiMH.
http://www.greenbatteries.com/bachfa.html#charger differences
Q
quietguy
I understand that NiMH batts lose their charge, when stored, much more
quickly than NiCds - I would find it annoying to discover my batts are
flat when I want to video something, so would choose to continue with
NiCds - but that's me.
David
