reprogram alarm co phone number via-30pse vista-10se
Janet Gilmore
I have an ademco, via-30pse or vista-10se, I am not sure which one. I
need to reprogram the phone number to call the alarm monitoring
service. I need to dial 1 and then the area code before the number.
Is this a DIY project? Making this change is not in the User's manual.
thanks
Crash Gordon
DIY? Not if you were my monitored client.
If you know the installer code you could do it yourself;
installer code+8+00 (beep) display should show; 20 - if not, you don't have
the installer code.
*41 enter your primary dialer string here then * (beep)
if you are using secondary reciever number as well
*42 enter your secondary dialer string here then * (beep)
*99 to exit programming
put system on test with CS and send some alarm signals
It's not in the User Manual because the user should not be doing this on
their own - one misplaced entry and your alarm system may not function as
you, or your CS, may expect.
| thanks
Bob Worthy
Why would one only need to program the telco number? Did a CS give you a
different number other than what was there? Are you just now setting this up
for the first time? There are alot of other functions that need to report
once connection is made. If you don't know percisely what panel you have and
you don't have a programming manual, how will you find all these other
locations that must be programmed to report correctly, ie zone types and
reporting codes, account numbers, secondary telco numbers, reporting format,
dialer attempts, fire zones, keypad reporting functions, turning features on
that you want and turning off features you don't want or need, etc.? How far
into this thing are you?
