req advice: problem with philips TV
tg
Philips TV 26PF5512D
I know this is a long shot but maybe someone out there is familiar with this
tv and knows why it freezes up. Here are some pics to go by:
http://www.zen187664.zen.co.uk/tv/
The problem occurrs when using the digital freeview channels - the TV
sometimes freezes up and won't respond to the remote control. It happens
often when I'm going through the program list for digital freeview.(second
picture down at the above link). Sometimes as I go up and down the program
list the TV will suddenly freeze up, nothing works on the remote control
except the off button and I have to switch the TV off. It takes about a
minute for the tv to come back on properly. If I wait a whole minute things
are usually ok again, but if I try to rush it and switch on before then it's
still problematic and won't display an image - I get a black screen,
sometimes with audio, sometimes not. I can't reproduce this problem at will,
it's random. Sometimes the TV is ok and other times it will freeze up. Does
anyone know where the problem might lie and which component I should replace
to cure this?
N
N_Cook
to cure this?
Bypass the internal freeview and feed in from an external set-top box? if
you can live with that
Sylvia Else
this
it's
will,
replace
to cure this?
Without claiming any sort of expertise on this, I'd have to suspect that
the big GENESIS display chip is freezing, which in turn could be due to
noise on the power supply line. Failing decoupling capacitors?
Sylvia.
tg
yes I can live with that no problem but I have elderly mother who can't.
