Sorting your hardware - req. advice on optimizing space/convenience
Mr. INTJ
I like to get some opinions from people on sorting their various parts
and hardware. I have very limited space for my home workshop...:
http://www.minsmithphoto.com/mrintj/workbench.jpg
As I've built up an inventory of components and hardware, rummaging
through random junk boxes looking for a specific part quickly became
the most time-consuming part of any project. I mounted some small
parts cabinets to my pegboard, and for some parts, like resistors &
capacitors, it was obvious how to divide them up according to value.
Not so obvious are things like screws, nuts and bolts, and other small
hardware. There seem to be an almost inifinite variety of sizes,
materials, thread types, wood screws, sheet metal screws, etc. Of
course, if I only have a handful, then it's not an issue (I'm not
_that_ anal retentive), but I have several pounds of screws, etc. in
all varieties - it takes way too long to find a certain screw (or even
worse, a matching set of two or more).
Do you folks sort your hardware into bags/drawers/etc, and if so, what
criteria do you use?
Thanks in advance.
Any other space-saving advice on workshop / workbench optimization is
greatly appreciated.
Mr. INTJ
San Diego
Curt Welch
Hum, bolt cutters. A tool I still have never owned. There always seems to
be another tool I feel like I must own even though I've never had a use for
them!
I guess you don't open your garage door very often since you seem to have
taken to using it for your hangers! :)
I don't like peg-boards anymore. I gave up on them long ago. It sure is
nice to see all your tools on the board but before too long, you have too
many tools and not enough space on the peg board. In addition, most the
peg board hooks don't stay in well, they tend to fall out when you try to
take tools off the peg board. I use tool chests with slide out drawers and
shelves for all my tools now. It works much better, but the tool chests
can be expensive and take up a lot of room.
But that's not what you were asking....
Back 30 years ago when I was last actually building electronic stuff, I did
the same thing you did - use those chests of plastic parts drawers to sort
out the standard parts like resistors and capacitors. They work ok, but
they are kinda tough to dig through. Pulling out each little drawer is
kinda slow and awkward and they tend to sick a lot (or get stuck when all
the leads from the 100 caps you put in the drawer start sticking out the
wrong way)..
I use clear plastic parts bins which I store in multiple drawers of a large
tool chest (the standard mechanics sort of thing when wheels and many
shallow drawers). I can open one drawer, and see all the screews, bolts
parts, etc laid out in the draw and fairly quickly spot what I need.
Instead of trying to pull out and look at 20 of those tiny plastic draws in
the parts chest like you have, I can pull out one big drawer, and see all
the screws and small parts in about 4 parts bins. Or when I buy screws by
the box, I can put the boxes in the drawers as well. This makes the
searching for the right part go much faster. I roughly sort the parts by
drawer with machine screws in one drawer, wood and metal screws in another,
etc. But other than the rough major sorting like that, it's mostly just
random in the drawer. Because you see everything in the drawer quickly,
it's not really so important for there to be any order to it.
Another trick I have used for the larger boxes of nails and screws which
tend to get piled on shelves is to use a hot glue gun and glue one of the
nails to the outside of the box so I can quickly see what type of nail or
screw is in the box without opening it. That also makes searching for the
right sized fastener go quicker if you have accumulated many boxes of nails
and fasteners like I have.
If you can't justify the cost or space for a good mechanics tool chest with
lots of big drawers, you might look into options of just adding (or
building) some large flat pull-out drawers to your current
shelves/workbench and then using those for all those little parts.
David L. Jones
Thanks in advance.
Mr. INTJ
San Diego
Here is a before/after shot of my small workshop after a recent
remodeling:
http://www.alternatezone.com/stuff/WorkshopBeforeAfter.jpg
The electronics side of the bench is here:
http://www.alternatezone.com/stuff/ElectronicsWorkbench.jpg
I have two benches, one for electronics and one for more crafty stuff
or the current project in hand etc. Allows two projects at once
easily.
Bigger mechanical stuff gets done on folding saw horses when the car
is removed from the garage.
Heaps more bench space and walking room now for the exact same area,
and a bonus spot to park the bikes as well (bench was deliberating
made that height to fit the bikes. More room to walk around the car
when it's parked too.
It's nice to be able to swing around on the chair from one bench to
the other.
The cabinets and shelves on the wall are custom made from pine. Big
tools and gear gets stored up in them.
The steel storage rack on the left is from Ikea. Very nice and easy
way to get multiple shelves above and below the bench. The shelf is
actually free standing behind the bench. The benches are mounted by
right angle brackets from the walls, so only require two front legs.
The electronics bench can actually fold up or down on the pivoting
wall brackets.
Lots of plastic draw cabinets for all the parts etc. Don't ask me how
they are sorted, still working on that!
The big plastic storage tubs under the left bench are very useful for
bigger items like power cords, rolls of wire and tape, gloves,
goggles, masks, or what have you. Three rows of those tubs on the
shelves.
Hope that gives you some ideas.
Lets me know if you want some better shots or details etc.
Regards
Dave.
Phil Allison
"Mr. INTJ"
** You left handed ?
Your test gear is on the opposite side to what I find natural.
Plus I have to have a lot more space for the item I am working on that you
have there - think Marshall tube amp head or a 16ch mixing console.
However, my soldering iron station is on the left - meaning I have to swap
hands when removing or replacing the iron.
..... Phil
Mr. INTJ
them!
I actually find myself pulling down the bolt cutters surprisingly
often, but I may be doing that for tasks where you'd use a more
appropriate tool that I don't own. ;-)
Yeah, we remodeled the garage into a portrait studio for my wife last
summer, so the garage door is now disconnected from the opener and
locked shut.
Yes, mine did that too and it was infuriating. I got some of these
little plastic retaining clips and put them everywhere. Now they stay
put.
(snip)
shallow drawers).  I can open one drawer, and see all the screws, bolts
the screws and small parts in about 4 parts bins.  Or when I buy screwsby
I'll give that some serious thought. The difficulty is more in terms
of available space than expense, but you make an excellent point about
being able to look down on everything, instead of sliding out one
drawer after another.
Wow, great tip!
Maybe I can mount some trays under the some of my shelves. To save
bench space, I already salvaged a discarded keyboard tray and mounted
it under one side of the work bench.
Mr. INTJ
(snip)
I really like what you did with the bikes. We have two bikes that I
haven't yet figured out what to do with. We also have a treadmill.
God, I want a bigger house.
the other.
One of those chairs has been on my list. Do you remember where you got
it?
Mr. INTJ
"Mr. INTJ"
....    Phil
Nope, I'm non-sinister. I bolted that vise in years ago - I'm probably
going to move it since it seems to divide my workspace neatly in half.
It was awkward to put the scope and power supply on the other side of
the vise, and I think I was trying to push it back a little onto the
adjoining shelf.
...but you're absolutely right - the work area that I have is just too
small - I end up doing things in my lap sometimes.
Phil Allison
"Mr. INTJ"
"Phil Allison"
"Mr. INTJ"
adjoining shelf.
....but you're absolutely right - the work area that I have is just too
** Something I find very good is to glue a layer of cheap carpet all over
the work area, it prevents scratching customer's valuable items - plus
stops small bits, electron tubes, microphones and fasteners rolling about or
dropping onto the floor and going missing.
Makes the work area far more comfortable for YOU in cool and hot weather
too.
Just make sure to always return the iron to its stand though .....
...... Phil
David L. Jones
Yes, the bikes were a big problem for us, so they really drove what
the final solution had to be.
Turned out really good in the end.
it?
Ebay Australia.
Dave.
Curt Welch
Joe Pfeiffer said:
While I agree about peg hooks, the solution isn't to do without the
pegboard, it's to use toggle bolts to hold tool racks to it. Most of
the tools will still go in the boxes (unless you have nwowhere near
enough tools!), but some of the most commonly-used can go on the wall.
Yeah, I think for electronics work that could make sense. I've not done
any real electronics work (except on the kitchen table) since I was in high
school 30 years ago. I do more woodworking, and metalworking, and home
maintenance stuff these days and for that, you have to deal with dust and
messy stuff like iron filings from grinding. Having tools out on a peg
board just gives the dust more places to make messy. It's easier to keep
things clean when most the tools are in closed drawers. I could see peg
boards working for an electronics bench if you didn't use those peg-board
hooks which pop out so easily (or found a way to secure them).
The other place I had tried peg board long ago was in the garage for yard
tools. Again, that's not a good fit because most peg boards don't work
very well for larger yard tools (shovels, rakes, etc). My last technique
for organizing the garage yard tools was just to attach horizontal 2x4s to
the wall and then screw in those large organizer hooks that can hold things
like shovels. It was an idea copied from my neighbor which has worked well
for me.
Curt Welch
Peter Bennett said:
The Stores group at work dispenses small parts in 2" x 3" clear
zip-lock plastic bags. These bags fit nicely in my plastic parts
drawers, and I can easily see what's in them.
I love zip lock bags. I found a place where for about $70 I could buy a
large assortment of bags in about 10 different sizes from 2"x2" to 14x15
(or sonething like that). My house and shelves are full of stuff in zip
lock bags now. I find it a great way to organize manuals and the extra
parts and paperwork for stuff I buy.
