HellasTechn
- Apr 14, 2013
- 1,579
- Joined
- Apr 14, 2013
- Messages
- 1,579
To keep this low voltage / cold supply side, still all isolated and safe, get a 9V transistor type battery, and use 2 flying wire leads, to connect battery + to a 470 ohm 1/2 W resistor and a lead to the other - terminal of the battery.
Your free end of the 470 resistor is going to connect to the pad of old R18 that went over to the 817 optical isolator.
Your batteries free flying lead will be held in hand to be temporarily touched to the negative power output terminal of the power supply.
If all is well in the 817 and the HOT side of the power supplies regulatory circuitry that that 817 phototransistor feeds, there will be a decrease in power supply output voltage, that you had read before, while holding that connection, just after powering up, for a short time needed to monitor the output voltage again.
This time it could be down to 9? 7? volts, but rise just as you lift the wire for the battery supplied LED power.
Should i run this test now that the prev one faield ?
