Resonator datasheet needed
nickagian1
Dec 5, 2005
45
Hi all!
Does anyone have a datasheet from a ceramic resonator (it doesn`t matter which)?
Basically what I want to know is which pin is what!
Can anybody help me with that?
audioguru2
Apr 6, 2004
12,022
It makes a big difference. There are ceramic resonators for AM radios, FM radios, shortwave radios and many other applications. There are many manufacturers, shapes and sizes. Digikey lists 563 different ones for sale. Which one?
nickagian1
Dec 5, 2005
45
:eek: I didn`t know it and unfortunately I don`t know exactly what resonator I have.
However I can tell that it has 3 pins and I have bought it to use in a project with a PIC microcontroller, if that helps you..
audioguru2
Apr 6, 2004
12,022
You bought something and you don't know anything about it. Really?
It has an input, an output and a ground. The input and output pins can be swapped, and the center pin is probably the ground pin.
nickagian1
Dec 5, 2005
45
I have asked for a ceramic resonator at about 10MHz for my microcontoller project and I was given this one...the only thing that is written on it is "L10.7A",which I guess shows the frequency, 10.7MHz...that is all I know about it! Oh and it has a red dot above one of the side pins..
But thanks anyway, because that is what I was looking for... I didn`t know which pin is for the ground...
audioguru2
Apr 6, 2004
12,022
You have a wideband tuned circuit for shaping the IF of an FM radio. A microcontroller uses a narrowband resonator that is like a quartz crystal. Try the one you have, it might work.
hotwaterwizard2
Jan 8, 2004
2,022
Nice Datasheet.
Here is a non electric Ceramic Resonator LOL
mvs sarma
Feb 12, 2006
234
hi Hotwaterwizard
SO NICE A Resonator
like to see it in 4th dimension--(i mean some one performing on it
sarma
MP1
Dec 7, 2003
3,397
Actually, that is not so. What he has is also used for microcontrollers. They are perfect for this application and much cheaper than a crystal. Just ground the middle pin and either of the outside pins can be connected to either of the clock pins on the micro. I have a drawer full of these for this application. I never use a crystal for a micro project, except for specific conditions where I need it. Resonators are commonly used instead of crystals. They take up less space on the pc board since you do not need the capacitors. It also sometimes eliminates routing problems on a pc board.
...of course, mine are much smaller than Hotwaterwizard's resonators  ;D
MP
audioguru2
Apr 6, 2004
12,022
MP
His is 10.7MHz which is a wideband ceramic filter for the IF of an FM radio. Microcontrollers also use a 3-pin ceramic resonator but they are narrow-band and are 0.5% accurate.
Digikey has a 4.000MHz 3-pin ceramic resonator with the capacitors built in for only $.34US each. Ceramic filters for FM radios cost much more.
MP1
Dec 7, 2003
3,397
Sure, 10.7 MHZ is a size used for IF, but micros also use various size Crystals for specific purposes. A 10.7 MHZ Resonator (or Crystal) will give you almost 3% less error in RS232 data transmission at 57600 baud than a 10 Mhz Resonator (or Crystal). I don't know what OP purchased since I am not clairvoyant, but I would be surprised if it did not work for this purpose. Even a digital gate based clock will work for a micro.
MP
ElectronicsGeek
Nov 2, 2006
15
10.7MHz resonator will work with microcontroller, even if it is defined as working up to 10MHz maximum.
However, the problem comes when if the program is written with the frequency of 10MHz, and now working with 10.7MHz things must happen in the wrong way.
Be careful with the 3-pin ceramic resonator (pin order always is: input-ground-output), as in some devices, the manufacturer already adds the internal caps across input and output to ground, so the enduser must not use the external caps. The only way you know that is identifying part from its marking on package and look up in the manufacturer's datasheet.
ElectronicsGeek
