Reverse-biasing an LED?
  • Thread starter Michael A. Covington
  • Start date
Would an ordinary red LED be damaged by reverse-biasing it with 12 volts
delivered through a 1k resistor?
I'm adding reverse-polarity protection to a circuit, and one LED will be
left unprotected unless I add a component.
I know the data sheets say not to reverse-bias LEDs, but I don't know how
much damage actually occurs, or how much resistance would prevent it.
Thanks!
Michael A. Covington - Artificial Intelligence Ctr - University of Georgia
"In the core C# language it is simply not possible to have an uninitialized
variable, a 'dangling' pointer, or an expression that indexes an array
beyond its bounds. Whole categories of bugs that routinely plague C and C++
programs are thus eliminated." - A. Hejlsberg, The C# Programming Language
W
Watson A.Name - Watt Sun, Dark Remover
The specs say the maximum reverse voltage is usually 5VDC, so anything
over that would exceed the maximum. But someone pointed out a
document that showed tests done in conditions simulating the
automobile environment, and tests showed that LEDs could hold up under
much higher reverse voltages without damage.
So, add the component. Like a 1N4148 or whatever.
If damage occurs it will probably be catastrophic.
@@F@r@o@m@@O@r@a@n@g@e@@C@o@u@n@t@y@,@@C@a@l@,@@w@h@e@r@e@@
###Got a Question about ELECTRONICS? Check HERE First:###
http://users.pandora.be/educypedia/electronics/databank.htm
My email address is whitelisted. *All* email sent to it
goes directly to the trash unless you add NOSPAM in the
Subject: line with other stuff. alondra101 <at> hotmail.com
Don't be ripped off by the big book dealers. Go to the URL
that will give you a choice and save you money(up to half).
http://www.everybookstore.com You'll be glad you did!
Just when you thought you had all this figured out, the gov't
changed it: http://physics.nist.gov/cuu/Units/binary.html
@@t@h@e@@a@f@f@l@u@e@n@t@@m@e@e@t@@t@h@e@@E@f@f@l@u@e@n@t@@
Chaos Master
Michael A. Covington[[email protected]] said this in
sci.electronics.components, at Sat, 3 Jan 2004 21:54:25 -0500, in article
In theory, yes. But it's tested that in automotive environments LED's may not
suffer from exposure to higher voltage.
Add an 1N4148 diode as protection.
IIRC, it would be something like this:
(If I am wrong, someone correct me, please. It's 03:45 AM here (Brazil)).
1N4148 (I think 1N400x series also works too)
1k_ | |
----|___|--.->|-.--.
| L.E.D |
Your 12V --- |
created by Andy?s ASCII-Circuit v1.24.140803 Beta www.tech-chat.de
Thanks. Even better, I'll put in a two-color LED: green for normal
operation, red for reverse polarity.
