RF Transmitters and Receivers?
jeff77789
Feb 23, 2013
17
I've been trying to use this pair of RF transmitter/receiver:
https://www.sparkfun.com/products/10534
https://www.sparkfun.com/products/10532
does anybody have any experience with what type of signal it actually sends/receives?
you see that in the datasheet for the receiver you have a digital output and a linear output as well.
I sent a pwm type output through this and it looks like it kind of successfully transfers but the signal is very noisy, disrupting the pwm signal. i dont think an analog voltage signal would transfer
thanks
jeff77789
Feb 23, 2013
17
okay so i finally figured out to find a digital signal to send through these. there is another problem that comes up:
1. the signal being sent to the transmitter is 9600 baud which is 2x the 4800baud for the tx/rx (which i do not know if it affects the signal any)
2. when i view the signal, it is very noisy and it looks like it is just random numbers. the thing is, if i turn off the Tx, the values stay in their random state and it looks like there is no uniformity
brevor
Apr 9, 2013
87
1. Sorry, you can't send 9600 baud data through a TX/RX that only supports up to 4800 baud.
2. Im not sure what you mean by this. Please explain a bit more.
Yeah, I'd certainly be trying to get it to work at 4800 baud before pushing it beyond its specs.
It *may* work at 9600 baud, but it may do so only with a very high signal, low noise, etc. Or it might not work at all.
jeff77789
Feb 23, 2013
17
Now I am at the point where i can send a digital signal at 4800 baud through these sensors.
The thing is, If it send "123" on the other side, i rarely ever get the "495051" sequence (refer to ASCII table)
the accuracy rate is less than 10% and I have no Idea why the signal is so "noisy"
is there any way i can improve on this?
