RFIDs close to HV power lines
Efthimios
Does any of you know if passive RFID will work close (3-4 meters) to
high voltage power lines (275kVolt).
I think yes since they work in FR frequencies and power lines have
60-50 Hz despite the strong electromagnetic fields. Do you agree???
Efthimios
Probably.
If you intend such RFIDs to be used by humans, isn't 3 metres a bit too
close to a 275 kV power line for safety?  Or do you mean 3 metres from the
projection of an overhead power line on the ground, when the line is at
least 7.2 m above the ground?
Chris
No within three meters from the power line. Lets assume that safety is
not an issue.
JosephKK
not an issue.
Not to make an issue, but as i recall minimum clearance at that
voltage is on the order of 4.5 meters.
