RGBIC/WS2811/WS2815 consumption in off mode.
LukasCZ
Dec 17, 2024
6
Prosím o radu, proužek ve vypnutém stavu má měřitelnou spotřebu ve wattech, je to možné? WS2815 dlouhý 5m má spotřebu 10w.
Please, is this a feature of the strip or where is the error? The strip connected to a power source without a controller has a consumption of 10W for the WS2815 strip and the consumption for the WS2811 strip is 3W
LukasCZ
Dec 17, 2024
6
Please advise, the strip in the off state has a measurable consumption in watts, is it possible? WS2815 5m long has a consumption of 10w.
Delta Prime
Jul 29, 2020
2,989
Yes, there is a quiescent current consumed by the controller-when it is enabled but there is no load.
Meaning the LEDs are off but only because the controller powers, the LED, but the controller itself is still powered and will consume current and do work & dissipate heat in watts, but this is on the micro amp scale. if connected to a battery pack, the measurable amount of current drawn from the controller would be less than the natural discharge current, of the battery itself.
LukasCZ
Dec 17, 2024
6
Okay, but why does the LED strip itself draw power when I just connect the power supply without the controller?
Delta Prime
Jul 29, 2020
2,989
That is a totally different question and I do have an answer for you. The LED’s themselves have a quiescent current 2.1 mA. That is an order of magnitude increase, then the controller.Page 3 of 8 pages. This is why data sheets are so important and the first thing you should research, or present a schematic or photographs of your set up, this also will help tremendously.
  • WS2815 LED Datasheet.pdf
LukasCZ
Dec 17, 2024
6
Okay, and why doesn't the controller stop powering the diodes when it's turned off remotely? It seems stupid and not economical to me. Is there a way to solve this? I'll have to add a switch between the power supply and the controller, which defeats the purpose of the remote control.
Delta Prime
Jul 29, 2020
2,989
Adding a switch is one solution I might add you are very observant that leaves me as a disadvantage because I do not know your application and I myself don’t want to do 100 questions tonight.
Maybe 200 questions that’s why I’m here :)
LukasCZ
Dec 17, 2024
6
Is there a controller or a way to connect it so that the supply is not empty?
