Ring generator for telecom
Andre Zanon
Does anyone knows a component, simple and not expensive for generating
the ringing voltage for a telephone? Something that would, with a few
external components raise the voltage from around 5V or 12V to the
ringing voltage of a telephone?
Michael A. Terrell
Ring gemerators are availible, but they are not cheap. In the US you
need a 20 Hz sinewave @ 90 VAC. Is this a permanent application, or
temprary? A small PA amp with a 70 Volt line output and any 20 Hz
oscillator woll work.
If you can find a surplus Western electric or other brand of 1A2
style key telephone power supply made for your country, it will have the
right output.
<http://search.ebay.com/search/search.dll?from=R40&satitle=Ring+Generator+>
has some used and surplus items, as well.
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
Ryan Weihl
google for "ring generator"
Andre Zanon
Andre Zanon escreveu:
Thanks, I will check,
This is a product we do in small quantities. Now I am using a
transformer that has 2 outputs: 10V CA and 40V CA, the second one I´ve
made a simple charge pump to generate the ring, and also the line
voltage 40V CC.
It is cheap this way, works well. But I am thinking about making
something better, but not very expenive.
Thanks again for the info,
André
Salmon Egg
This sounds like a job for a transformer. 5:1 step up transformer should be
adequate for stepping up 12VACrms to 60VACrms. I do not know for sure, but I
expect that would be adequate for ringing. You could use a 60Hz to do that,
but you must remember that the primary and secondary voltage ratings are
inversely proportional to operating frequency. That is, for a ringing
frequency of 20Hz, the primary should be rated for 36V while the secondary
should be rated at 180V.
Bill
-- Fermez le Bush
Michael A. Terrell
Real telephone bells require the right frequency to ring. The coil
and capacitor are a series resonant circuit, and in the days of party
lines, multiple users had different ring frequencies.
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
