RMS voltage of a square wave
panfilero
I was wondering if I take the RMS voltage of a messy looking square
wave, a noisy square wave, with some measurement device, and I want to
know the regular current of the thing can I take the RMS current and
divide it by the square root of 2 in order to get my regular current?
I know you can do this for sinusoidal ac signals but don't know if the
math still works out the same for other signals...
PS - I got my RMS current value by dividing the RMS voltage value by a
known resistance I have in my circuit
Much Thanks for any responses I get
Bob Eld
Yes the RMS current is the RMS voltage devided by R.
No, the "regualr curent" What ever that is, is not the RMS current divided
by the square root of two. With a sign wave, the peak current divided by the
the square root of two is the RMS current, but ONLY for a sign wave.
With any other waveform, the the square root of two relation does NOT hold.
It must be calculated from first principles or measured with a true RMS
meter.
The equation for the RMS current is: Irms = ((int i(t)^2 dt )/ T)^1/2
Where i(t) is the current as a function of time, T is the time over which
the integral is taken, ( 0 to T ), usually one period of the wave.
That is, in words, the RMS current is the square root of the average time
integral of the current squared.
For a square wave of current Ip going plus and minus over a period of T the
RMS value is:
Irms =( ( (Ip^2 *T/2 + (-Ip)^2 * T/2)) / T)^1/2 = ( (Ip ^2)/2 +
(Ip^2)/2)^1/2 = (Ip ^2)^1/2
Irms = Ip, The RMS equals the peak value for a square wave. It very much
more complicated if noise is present.
BobG
The RMS of an on and off wave is the average. Try it with 1V and 0V.
Then you have to believe that it also works with 5v and 0v.
Bob Eld
Thats right. In the example I gave the wave was plus and minus, not plus and
zero.
K
krw
[email protected]>, [email protected]
says...
Sample the waveform at whatever frequency you like, square each
sample, average the squares, and take the square root (root of the
mean squares). It doesn't matter what the waveform looks like, this
algorithm works.
Absolutely. ...sorta by definition. ;-)
Yes. Think about it this way... RMS is used to measure power
because power is proportional to the square of the voltage (or
current), so to get the "effective" voltage of an arbitrary waveform
you need to average the square of the voltages. This also has the
benefit of deriving real power with negative voltages. The average
of the voltages doesn't tell you much (the average of your wall
outlet is zero).
No problem.
BobG
The average
outlet is zero).
Not after sampling and squaring. The power is all positive, like the
squared samples.
Phil Allison
"BobG"
** Completely wrong !!
RMS current or voltage follow the square root of the duty cycle.
Eg: with a duty cycle of 0.5 ( square wave) the RMS value is 0.7071 of the
peak.
...... Phil
Bob Eld
Phil Allison said:
"BobG"
peak.
..... Phil
Vrms = ((vp^2) *T/2 + 0) *1/T) ^1/2 = ((Vp ^2) / 2 )^1/2 = Vp/ (2 ^1/2)...
Yep, for 50% duty cycle, Vrms = Vp/ (sqr 2) if the other half of the wave
is zero.
Phil Allison
"Bob Eld"
"Phil Allison"
"BobG"
^1/2)...
is zero.
** Keep it simple:
For a rectangular wave,
V (or I) rms = sq.rt Duty Cycle ( expressed as a decimal fraction )
For a bi-polar, rectangular wave - first rectify the wave.
...... Phil
Bill Bowden
Look at it this way: You have a 1KW space heater you run half the time
(1 hour on and 1 hour off). The average power is 500 watts. Say the
heater voltage is 100 VDC and the current is 10 amps, and the heater
resistance is 10 ohms. So, the question is what RMS voltage will give
you 500 watts at 10 ohms and 100 volts peak? Work that out and we find
the voltage to be 70.7 and the RMS current to be 7.07 amps.
So, it looks like for a square wave, the RMS voltage or current is the
peak divided by the square root of 2.
-Bill
Salmon Egg
IIRC, although it is easy to check, the rms voltage of a series of
rectangular pulses will be the square root of the peak current times the
average current.
Bill
Don Kelly
The average
outlet is zero).
squared samples.
But the average of the squared values is not the average value of the
voltage and taking the root of the average of V*2 will not, in general, give
you the average of V.
It will give the rms value which was devised originally as a way to get an
"equal Power" to DC with the same load- as krw indicates.
Don Kelly
Bob Eld and Phil Allison have dealt with this topic except for the question
"how did you measure the rms voltage?".
If you are using a true rms meter which samples at a high enough rate- then
you are OK.
If you are using a cheaper multimeter on the normal "rms" scale, then it
simply assumes that the AC measurement is sinusoidal and scales from the DC
average accordingly and will not give the correct value except for a
sinusoid or for an On/Off cycle with equal on and off periods.
Phil Allison
"Don Kelly"
question "how did you measure the rms voltage?".
then you are OK.
The " true rms" function on a DMM is *not* obtained by sampling. It is
normally obtained by the use of a " true rms to DC" converter IC -
generally one made by Analog Devices like the AD736.
DC average accordingly and will not give the correct value except for a
** Most DMMs use a precision rectifier circuit followed by RC averaging of
the output and then DC scaling so that the final reading equals the rms
value of a sine wave input ** within** the particular meter's specified
frequency range.
Mostly, this range is very narrow - ie from about 30Hz to a mere 1kHz (with
+/- 1% accuracy).
So, unless you KNOW the energy spectrum of your wave falls inside this
narrow band, the reading can be way wrong -ie well below the actual value.
Unfortunately, most " true rms " DMMs have the same frequency range issue -
some of the more expensive ones work out to 20kHz or 100 kHz with good
accuracy.
The only * low cost * solution is to examine the wave on a scope and then
compute the rectified average and rms values - not possible with any
accuracy if the wave is noise like.
...... Phil
K
krw
How about a precision resistor placed inside a calorimeter :) The heat
dissipated is a direct measure of RMS current squared.
Calorimetry is notoriously difficult. Ask Pons and Fleishman. ;-)
Wasn't this done with some high-freq RF stuff at one time? Measured the
temperature or wattage of a resistor or something like that?
Yes, I used an HP true RMS voltmeter when I was in college. It was
a marvelously expensive widget and they didn't like mere students
using it. ;-) It's likely the best way to measure true RMS voltage
at high frequency. I suppose you could read current with the same
meter. ;-)
K
krw
"Don Kelly"
Slick, though not perfect.
frequency range.
Normally <> is not
It *is* used, though perhaps not in handheld DVMs. IT is used in
Kill-a-Watts.
+/- 1% accuracy).
accuracy.
How do you get better than 1% accuracy on a scope? Sampling works
to any accuracy one desires and can go fairly high in frequency.
Even higher if the waveform is repetitive.
Phil Allison
"krw"
Phil Allison
"Don Kelly"
** Err - so just like you ?
Normally <> is not
** Bollocks .
** You are not paying attention to the point at issue - fuckwit.
BTW:
Fix your stupid settings so the name of the poster you arr replying to is
left visible.
....... Phil
Phil Allison
"daestrom"
*PROVIDED* you measured that voltage with a true RMS voltmeter, then yes,
you have the true RMS current.
** It ain't that simple.
The vast majority of so called " true rms " AC ranges fitted to DMMs are
of very limited bandwidth - typically 30Hz to 1kHz within 1% accuracy, a few
more expensive examples go to 20 kHz or even 100kHz.
So, unless the voltage wave under test falls within the particular meter's
bandwidth, the reading will be in error and likely very seriously so.
...... Phil
K
krw
"krw"
Phil Allison
"Don Kelly"
No Phyllis, you're the only one who's perfect in this conversation.
Perfect asshole, but perfect none the less.
Try reading it. ...only three words and an inequality,
** Bollocks .
You're wrong, as usual.
The only point you have is between your shoulders, Phyllis.
BTW:
left visible.
You're as wrong as Dimbulb, Dimwit.
Phil Allison
"krw" = just another autistic cunthead
**** off and die
- you festering pile of sub human excrement.
..... Phil
