I.M.H.O use Ultrasonics.
-Simpler to interface with
-Cheaper to interface with
-Simple distance calculations the doppler effect is readilly available
In small distances you can not expect big RF signal variations indicating distance changes in the cm range.
Ultrasonic and RF beacons are most of the time found wotking together like this:
-According to the RF signal find which ultrasonic is operating.
Eitherway the signal strenth in dB can be used to find the distance from the RF beacon.
There is an attachement showing the relationship of signal strength with the distance. Once you find this the rest is easy. I can help you with the rest
FAQ-0005.pdf.zip
