Robotics
Sumit Saraogi
Dec 19, 2004
17
Hey Thinking Of Working Out A Robot That can perform all the elementary functions.
All those of you interested in sharing ideas can post your message.
Sumit
Kevin Weddle
Feb 23, 2004
1,620
I work around robots all the time. The code seems very high level. Which means there is a lot more slack in the system. I would even say they are easy to build. I think what helps is that since the robots are typically slow compared with processor speeds, the real time function is easy to achieve. In fact many robots can work without a real servo system. They can rely on external inputs from sensors.
Sumit Saraogi
Dec 19, 2004
17
Hey Kevin
      Thanx a lot for ur valuable suggesstion.
CAn u let me know that what is ur work field exactly and what alll knowledge and requirements i need to fulfil before making a College Project on Robotics
Waiting for ur reply
sumit
Sumit Saraogi
Dec 19, 2004
17
Kevin I didn't get ur first line. What did it exactly mean about code n high levels n slacks etc...Can u let me know what all components r required and where can i get them.
Regards
Sumit
trigger
Aug 7, 2004
236
robots is a combination of electronics, porgramming and mechanical  monster..... :p
What Kevin refer to is the program codes on the MCU to control the robots.
Sumit Saraogi
Dec 19, 2004
17
Hi Trigger
    Thanks for the info.
    Just let me know from where to start off for the project.
    I mean there has to be good knowledge of components to be used ( electronic & mechanical)
    I am thinking of starting of firstly for making amoition control proram. Also I don't have much knowledge about Mechanical engg , will that be a problem.
what is the estimated cost of a College project on Robotics.
have u ever worked on one
neways
thanks again
bye
sumit
