Rotel AN50 Amp help
MyNews
Hi can anyone out there supply a schematic for a Rotel AN50 Amp?
Alternatively I would be just as happy to have the pin outs for the power
amp IC ( SI-1735HDF). My amp needs a new power amp IC and I can not source
one anywhere. I am thinking that I will try a STK type IC but need the
original pinouts to compare with the STK. Maybe someone out there has
already tried this? Thanking you all in advance.
Con
N
N Cook
Con
The voltage on the main power rails dictates the wattage
Its a matter of determining the +,- and ground rails and output line/s
the inv and non-inv i/ps should be reasonably determinable, listening with a
crystal earpiece/ scope when old chip is removed and safe to power up empty
the standby/mute lines would go to the relevant part of the design rather
than preamp area.
That just ;-) leaves bypass, compensation, bootstrap, filter etc lines.
When I've done this I've put some resistors, 10s of ohms, in the +/- feeds
and 100 ohms or so in the questionable ones until more sure
I have the pinning for the Sanken Si1135HD if any use
remember if its a stereo hybrid device you can use 2 mono ones with a bit of
jiggery pockery
