RS-485 (MAX487 / MAX485) - On-chip fail-safe feature
esm.
Feb 19, 2012
26
Hello all.
I have a good knowledge on RS-485 buses. I have some doubts about the internal fail-safe feature of MAX487.
I know how to do a fail-safe biasing using external pull-up and pull-down resistors, but my doubt is just about the internal fail-safe feature of these transceivers.
Currently I can't do tests in practice with my ICs (MAX487). I won't use a MAX485 because I could need more than 32 nodes attached to the RS485 bus (MAX487 supports up to 128 nodes).
When receiving at the RS485 bus, I know that:
VA-VB >= 200mV ---> RO pin is level '1'
VA-VB <= 200mV ---> RO pin is level '0'
VA-VB > 200mV && < 200mV ---> RO pin has undeterminated logic state
MAX487 / MAX485 datasheet says: The receiver input has a fail-safe feature that guarantees a logic-high output if the input is open circuit.
Considering the following condition:
1) Supply voltage = 5V
2) DE and RE pins at level '0' constantly (that means transmit is disabled and receive is enabled)
3) A and B pins left floating (No termination resistor and no fail-safe biasing external resistors connected). Nothing connected to both pins A and B
Questions
1) Does these RS485 tranceivers have an internal pull-up from pin A to VCC and a internal pull-down from pin B do GND? (with higher values?)
2) In this condition, what should be the voltage between A and B (5V)? (Considering a very high input impedance meter)
3) At question 2, the logic level at RO pin is '1', right?
4) Now, if I put just a termination resistor (120 Ohms) between A and B, the logic level at RO will be 'undeterminated', right? I think if the internal resistors are present, they will have a high value and the voltage between A and B will be near to 0V due to the low resistance of the termination.
I really have these doubts a long time.
Someone can help?
KrisBlueNZ
Sadly passed away in 2015
Nov 28, 2011
8,393
I'll try to help, but don't take this as gospel.
1. No, I don't think so. The "fail-safe" feature works by guaranteeing that if the data lines are at the same voltage, the receiver output is high. So, they have changed the behaviour whereby |VA-VB| < 200mV gives an undefined output, because the output state IS defined for at least half of that 400 mV range. Because of the internal A-B resistance, if the inputs are disconnected or the bus is undriven and |VA-VB| is zero (or near zero), the receiver output will be high. Pullup/pulldown resistors aren't needed and aren't used. This is all AFAIK!
2. Zero volts
3. Yes
4. No. If you add a termination resistor, |VA-VB| will be zero and the receiver output will be high.
I repeat, this is all AFAIK, based on my previous understanding of this feature and reading the data sheets. I haven't tested this myself.
Finally, I looked at the data sheet (19-0122 revision 9 of 2009-09) and it doesn't mention anything about this feature for any of the devices covered. It states that for all devices, |VA-VB| < 200 mV gives an undefined output state. I know Maxim offers that feature but perhaps you should check that the MAX487 (still) has it?
esm.
Feb 19, 2012
26
Here is my current schematic, attached in PDF and PNG.
I would like to design this schematic for use in RS-485 buses with a maximum of around 64 nodes.
I have some doubts about this schematic yet:
1) For R3 and R8 (fail-safe biasing), I am using 560 Ohms. Somebody know which are the most commom values used for fail-safe biasing?
2) Also for R3 and R8. I am using through hole resistors (250mW / CR25 body). Could I change them to 560 Ohms SMD 1206??? (because I am already this SMD value). That would be great!
3) Would be more suitable connect the fail-safe resistors directly to EIA485_A and EIA485_B nets, instead of connecting them to A and B nets ???
4) Maybe would be better to change the values of resistors R5 and R7 (inrush protection) ???
5) The differential voltage between A and B lines of an RS-485 bus is +- 5V, according to MAX487's datasheet. Is it recommended to place a 5V TVS diode between A and B nets? Like a SM05 TVS diode, for example? For differential protection?
Some recommendations for this schematic? Change components values?
  • SCH.pdf
KrisBlueNZ
Nov 28, 2011
8,393
Re guaranteed high receiver output on undriven RS-485 bus.
The MAX48x data sheet says only that the receiver has a fail-safe feature that guarantees a logic high receiver output when the inputs are disconnected; it doesn't say how this works.
My comments on offsetting the differential input voltage threshold don't apply to the Maxim devices at all, as far as I can tell. Sipex (now Exar) make several devices that have this feature, including the SP1486E, which is designed for Profibus and has a lot of features you might like:
5V operation
1/8th unit load (up to 256 devices on the bus)
Receiver failsafe (output high) on open, short, and undriven bus
The receivers have a fairly tightly controlled differential voltage threshold of -125 mV (nominal), rather than 0V, so you don't need bus biasing resistors to get a guaranteed receiver failsafe on a normally terminated RS-485 bus.
See http://www.exar.com/connectivity/transceiver/rs485
