That's a neat item, too. Don't know how you found so many. Must be better at
google searches than me. It doesn't say how to communicate with the AR-2
Relay Interface. Send characters? Toggle DTR, RTS? I emailed the company to
get details.
Hi David,
I started getting all kinds of ideas too when I saw what was out
there. I'm glad you asked about these things! Here is what they say
about the AR-2, they also have an AR-2S that comes with 2 digital
inputs.
AR-2 RELAY INTERFACE...The AR-2 relay interface is a stand alone relay
interface for connection to RS-232 which provides software control of
(2) relays which are included and mounted on the AR-2 circuit
assembly. The relays are energized or de-energized by using the RS-232
control signals DTR and RTS. The AR-2 relay interface is used when
only 1 or 2 relays are required (such as to control a line printer).
The AR-2 is only for use with RS-232 ports which support DTR and RTS
and is not expandable. The EN-B instrument case may be used to house
the AR-2 if an enclosure is required. The relays are SPDT rated at 12
amp 240 volts AC. A terminal block is provided for power supply and
relay contact connections. Requires the PS-GP-1 power supply and
serial cable (sold separately). RS-232 connection is via a DE-9 (to
order cable, add the suffix /AR-2 to the any of the serial cables
shown in the section describing connector cables). The AR-2 may be
connected to USB using the CO-USB converter. Control software examples
in Basic, Visual Basic and C are provided with the order. COM 1 thru
COM 4 supported. Dimensions... 2.375" by 3".
AR-2S RELAY INTERFACE...The AR-2S relay interface is similar to the
AR-2, except that two digital inputs are provided in addition to the
two relays. The inputs may be used to input the on/off status of push
buttons, contacts, alarms or to determine the status of equipment,
etc. (inputs are optically isolated). Input status is indicated via
the RS-232 status lines DSR and DCD (CTS may be used as a supervisory
signal to monitor for the AR-2S connection and power). A terminal
block is provided for connection to the inputs, power source and relay
contacts. The EN-B instrument case may be used to house the AR-2S if
an enclosure is required. Requires the PS-GP-1 power supply and serial
cable (sold separately). RS-232 connection is via a DE-9 (to order
cable, add the suffix /AR-2S to the any of the serial cables shown in
the section describing connector cables). Relays are rated at 12 amp,
240 VAC with SPDT contacts. COM 1 thru COM 4 supported. The AR-2S may
be connected to USB using the CO-USB converter. Includes reference and
software. Dimensions are 3" by 3".
http://www.eeci.com/eeci2.htm#ar-2
Good luck.
-Graham
