RS422 to RS232 converter.
HellasTechn
Apr 14, 2013
1,579
Good day !
I have been searching the net for some cheap RS422 to RS232 converter. While i have found tons of RS232 to RS422 converters, i have found none to do the opposite.
Anyone have an idea where i can find one or a circuit diagram i could use to build one ?
Thank You !
kellys_eye
Jun 25, 2010
6,512
There isn't one because you'd have to 'choke' the RS422 signal (10Mb/s) back to under 1Mb/s for the RS232 to work. Not to mention the multi-drop facility.....
If you wanted one I suspect you'd have to use opto-couplers to maintain the system balance and the opto-couplers outputs simply switch at RS232 levels (real or 'fake') with a ground reference.
HellasTechn
Apr 14, 2013
1,579
What do you mean switch ar rs232 levels ? could you explain more please ? or could you make a diagram ?
HellasTechn
Apr 14, 2013
1,579
Here i should say that i can use either TTL level rs232 like the one used by UART or hardware rs232 signals that are then converted to TTL level with the transistor inverter circuit.
kellys_eye
Jun 25, 2010
6,512
you answered yourself....
'True' RS232 uses a ± supply (generally 12V) but that's quite rare these days - note the legacy -12V supply line on some PC power supplies - but TTL level is more prevalent now.
Minder
Apr 24, 2015
3,561
I built one for for converting bi directional RS244-RS232 to a Mitsubishi PLC, it is based on the Beijer cable version, The IC's used are a couple of 75179 and a MAX202.
M.
dorke
Jun 20, 2015
2,342
Well,
Apart of the powering issue these devices are bidirectional!
i.e they perform both ways, so they are basically doing 2 ways conversions.
1. Use an externally powered device.
2. Think about the RS-422 termination issue.
3. Like Kelly said,assumption of low enough baud rate to be comparable with both standards.
HellasTechn
Apr 14, 2013
1,579
OK. i have an rs232 transmitter and an rs232receiver. The receiver is not supposed to send anything back to the transmitter. Only "listen"...
dorke
Jun 20, 2015
2,342
Is this for the same last project that was uploaded here?
Why do you need RS-422?
It is(was) usually used for long distance,high speed (relative to RS-232).
HellasTechn
Apr 14, 2013
1,579
The concept is the same but the project is different.
I had an rs232 transmitter that i needed converted to TTL to supply a Microcontroller.
Now i have an rs422 transmitter that i need to convert it to TTL to supply the same type microcontroller. Only in this case the problem is that the Microcontroller only supports 2 wire comm (data and gnd like the rs232).
HellasTechn
Apr 14, 2013
1,579
This show it a little clearer, you may be able to adapt it.
The 4 IC's on the left are 2 75179b, the one on the right is a MAX202.
Half way down.
http://forums.mrplc.com/index.php?/profile/52109-akahige/&do=content&type=forums_topic_post&page=2
My concern is that since i need TTL signals in the first place then why not just use the signal on line B instead of building the circuit that will give me a -5V to +5v rs232 ?
First chance i get, i will use the Oscope and check the rs422 lines to see if they really are as shown in the picture and then if they are... i will try to beed line B to the microcontroller to see if it can read it.
dorke
Jun 20, 2015
2,342
In this case (listen only).
Use a receiver IC like the AM26C32 ,MC3486 or DS3486 ,you actually need a single receiver (of the 4 in the IC).
There are also dual receiver ICs like the uA/MC9637
These are ICs requiring a single +5v p.s for operation.
Using a single line(unbalanced, like RS-423) is possible,but highly not recommended !
You can not directly connect it to TTL!
In any case you should have a dedicated receiver to translate the levels.
If the output is RS-422 it should have a spec. defining the speed,range etc.
Using an unbalanced receiver will limit the range and speed possible,
as well as noise immunity and ESD capability.
The receiver end should have a termination resistor.
Typically a single 100 ohm at the furthest receiver point.
In any case you should use 2 wires(422 or 423).
What is the operating speed?
What is the range?
How many receivers listening on the line?
HellasTechn
Apr 14, 2013
1,579
Do they provide rs232 (-12V - +12V) ? or TTL (0V - +5V) ?
I understand...
I am not sure.
4800 BPS
What is the range?
about 30 meters.
one rs422 and one rs232 (microcontroller).
I think i should have provided the diagram in post 1. Sorry !
In the diagram below, the red line is what i was thinking to try.
P.S.
The microcontroller will use two different inputs to read each transmitter and only write to the LCD. The rs422 receiver has two different inputs, will "listen only" and will not send back anything to the transmitters.
There is really nothing more than that. in other words the receivers work
independently and use the transmitter only to obtain certain information.
dorke
Jun 20, 2015
2,342
You have low speed and short distance.
But,
Actually you have 2 transmitters feeding 2 receivers .
Is the uC for just monitoring the the "working line"?
The ICs would be perfect for you,you can get one for about 1$.
Place them on the uC board power them with 5V.
They provide TTL level signals at their output to be used by the uC.
You will gain nothing by working un-balanced,stick to the balanced RS-422.
