Running a 170watt fan on same power strip/board as laptop and PC
DaveyK
Hi
I have a double power point/outlet, with two power boards/strips. 220+v?
Australia Max 2400watts?
Can I run a cooling/pedestal fan of 170 watts, on the same power strip/board
as a PC and laptop? Will this cause power drain to the hard drives.
I ask this as I was told by an electrician, not to have an air-conditioner
on the same power circuit as my PC, or hard drive damage may occur, not to
mention running too many watts for the outlet.
(I've actually got one 170watt fan and another 70watt on another power
point/outlet.)
So are fans generally safe on the same power strips/boards as PC's. (All
things being equal - not trying to use > 2400 watts on that power
outlet/point.) and not using far too many peripherals etc. on that strip. I
may have to check the power circuits in the house to evaluate which power
outlets/points are on the same circuit.
Thanks in advance. I hope you understand my rant fairly easily.
Palindrome
DaveyK said:
Hi
strip/board as a PC and laptop? Will this cause power drain to the hard
drives.
air-conditioner on the same power circuit as my PC, or hard drive damage
may occur, not to mention running too many watts for the outlet.
point/outlet.)
strip. I may have to check the power circuits in the house to evaluate
which power outlets/points are on the same circuit.
No problem. Your fans aren't going to have any detrimental effect,
where-ever you plug them in.
Portable ACUs or room heaters are an order of magnitude greater when it
comes to electricity demand. Best used either directly plugged into a
wall socket or on an (unwound) dedicated extension lead plugged directly
into a wall socket.
The tame electrician possibly meant to say not to plug in such high
demand units on the same extension lead as your computers. A long
extension lead with computers and an ACU plugged in at the end can
affect the quality of the supply that the computer sees as the ACU
switches on and off.
Even so, I do suggest that you consider buying a UPS for your computer.
It will remove most power irregularities - including most of those sent
down the power lines from the supplier and other consumers. Just don't
plug an ACU into one of its outlets..
DaveyK
Thanks Sue. Much appreciated
comes to electricity demand. Best used either directly plugged into a wall
socket or on an (unwound) dedicated extension lead plugged directly into a
wall socket.
The tame electrician possibly meant to say not to plug in such high demand
units on the same extension lead as your computers. A long extension lead
with computers and an ACU plugged in at the end can affect the quality of
the supply that the computer sees as the ACU switches on and off.
Even so, I do suggest that you consider buying a UPS for your computer. It
will remove most power irregularities - including most of those sent down
the power lines from the supplier and other consumers. Just don't plug an
Don Kelly
wall socket.
Sue, you done did good! Well said!
