Rutland ESB57 Energiser low voltage help!
emlet
Jul 24, 2018
3
Hello all knowledgeable people!
I have tested my electric fence energiser with a fence tester in isolation of the fenceline so using the tester on the earth and live of the energiser itself and am getting 1.8/1.9kv reading. it should be around 6kv so something is not quite right!
I have taken the back off and nothing is obviously loose, perished,burnt or looking obviously a miss to the uneducated persons eye. It would cost me 90.00 to send the unit off to be fixed, money i just don't have and as my sheep are merrily ruining my fenceline as i type I really need to find the fault and get it repaired pronto!
And help with finding the fault explained in non electrical speak gratefully received. IMG_0785.JPG IMG_0783.JPG IMG_0782.JPG
duke37
Jan 9, 2011
5,364
I would check the voltage on the 3.3μF capacitor. I expect it should be about 400V. Do not kill yourself:).
There is another component nearby with a yellowish patch, possibly just a trick of the light.
The next thing to check is the EHT tranformer, this may be the transformer with the twin bobbins or that round one nearby.
I could perhaps lend you an archaic fencer if you are not too far away so that your sheep may safely graze.
kellys_eye
Jun 25, 2010
6,512
Change the big capacitor! It's a common cause for 'low' output. Just be sure to get a decent quality replacement.
emlet
Jul 24, 2018
3
HI thanks, do you mean the 'big yellow' object with LCR on? sorry i have no electrical knowledge im having to google everything! And do you know a good online shop for parts like this by any chance so i can see how much they cost. Many Thanks
emlet
Jul 24, 2018
3
that is a very kind offer duke37 thank you! I am a bit far away to accept unfortunately.
I only have a fence tester. I assume i would need some proper 'leccy kit to test the components? If i would have to buy testing kit i may as well bite the bullet and send it off to be repaired instead and teh price will end up the same and even if i found the fault i cant replace it myself or would muck the whole board up trying and still have to send it off! I get frustrated when i cant do a job myself!
duke37
Jan 9, 2011
5,364
Good quality capacitors can be obtained from RS comonents or Farnel. The 3.3μF capacitor has a hard time and there are special expensive capacitors available used in Gallagher fencers
Edit: RS components
Vishay polypropylene 600V 3.3μF, £6.16
