Sallen and Key Nodal Equations
Chr1s
Dec 20, 2016
27
Can anyone help me with this problem? i am not quite sure where to start?
14,317
Start by labeling the voltages across the components with unique labels (V1, V2, V3, ...).
Use complex impedances (frequency dependent) for the capacitors - you should know how to express those.
Use Kirchhoff's voltage law to set up equations for the mesh voltages.
Transform the resulting equations to match the standard form.
As a prerequisite assume an ideal operational amplifier with infinite input impedance (equivalent to Iinput = 0 A) and infinite gain (equivalent to V(in_+) - V(in_-) = 0V)
LvW
Apr 12, 2014
604
Everything OK with Harald`s answer.
Nevertheless, according to my experience it is more easy to use Kirchhoff`s current law for each oif the various nodes (using the voltages between each node and ground).
